Stainless Steel Braided AC , Heater and Powersteering Hoses
I have been searching for these for a long time and just found some, in case any one else is also looking http://www.custommadehoses.com/ac_heater.html
Well, I've been wanting these for a long time too and am thinking of going with either CoolFlex or Earl's Form a Flex for the radiator hoses. You can not use braided line as the radius of some of the turns are way too tight for braided hose. In fact, in their pictures it looks as if they used CoolFlex hose for the radiator. The problem I found on the heater hoses is that they both change diameter from one end to the other. They start out as 3/4" and end up as 5/8" on the other end. How is that going to be solved?? If anybody has ideas let me know as I want to replace all this stuff.
Thanks
Bryan
parbreak
Thanks
Bryan
parbreak
Thanks
Bryan
parbreak
Thanks
Bryan
parbreak
Originally Posted by cgworth
what does he do for the short hose connected to the ac canister? will he resolder it?
Yea, he cuts off the OEM AC ends and welds them to male AN fittings.. then you are good to go. The hoses are special for AC so the freon does not leak out..
You can see them pretty good in this pic:
