Removal of 'Objects in mirror are closer then they appear'
I need to know if anyone has had any luck removing this off of their passenger side side view mirror. thanks in advance! -Jim
accualy, thats what i was gonna do, and wanted the passenger side to match, but somebody was telling me it will come off with a razor blade, but i guess not?
Originally Posted by Jabroni
Just get "Objects in mirror are about to disappear" etched into your driver's side mirror! ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
that or i beilve autozone has cut to fit plastic mirrors you can cut to fit whatever side mirror you need.
Originally Posted by ta12sec
local glass compay should be able to cut you a piec of mirror that doesnt have the warning on it
Originally Posted by 2000BlkCamaroSS
Shouldn't you be able to polish the words out of the glass or will it only cause it to look like ****? If so, how do you do it?
If you have a glass shop cut you a new piece (or do it yourself), it probably wouldn't apply anyway - it is there because the passenger side mirror is slightly curved, and they'd just use regular mirror. The fitment isn't usually as good as stock, though, so I wouldn't recommend doing it unless you need a replacement.
