LEDs drain battery?
Old Mar 31, 2005 | 01:28 PM
neonblack's Avatar
Default LEDs drain battery?
I was planning on putting in some LEDs in my clear corners, but someone just told me that they will drain the battery. Has anyone heard of this as a problem with LEDs?
Thanks...
Old Mar 31, 2005 | 01:44 PM
Ws6Extreme's Avatar
This is true.. very unfortunate but true.
LED's (while on) will draw power from your battery. On the bright side they only draw a FRACTION of what an incandescent bulb will draw...
Think of it this way. Your battery supplies power to super heat the filament in an incandescent bulb producing light (controlled short). LED's use the power from your battery to illuminated by the movement of electrons in a semiconductor material. This is why they last so long. They are a solid state device.
Old Mar 31, 2005 | 04:17 PM
LS1_2NV's Avatar
So, is this bad? I just spent 30 bux ordering them for my clear-smoked corners...tell me I didn't just waste my $!
Old Mar 31, 2005 | 04:20 PM
LS1_SS's Avatar
LED's are better than regular bulbs.. they last longer and use much less power!!
Old Mar 31, 2005 | 04:37 PM
LS1_2NV's Avatar
Well, that's exactly why I bought them! I didn't think there would be any problems, but when I read this, DOH! Anyways, has anybody ran into charging/battery problems with them (think I will running four LED's)?
Old Mar 31, 2005 | 04:42 PM
Ws6Extreme's Avatar
Sorry I was trying to be sarcastic...
Bottom Line.
-With LED's you free up power that incandescent lights will rob you of.
-LED's take less power to run there for more power for your battery
-LED's are FAR more reliable, and resistant to shock.
LED's are in EVERY way are far better then incandescent bulbs.. You are better for having them.
Old Mar 31, 2005 | 04:45 PM
meissenation's Avatar
Yeah I was going to say I've been running about 10 LEDs inside my interior for like 6 months and not a single problem with my battery, and that's with 5 of the LEDs being on a dim state 24/7 even when the car is off (apparently if you put LEDs tapping from the power lines that go to the dome light, there's ALWAYS a little power going through that line..)
Old Mar 31, 2005 | 04:48 PM
LS1_2NV's Avatar
B-E-A-utiful! Wanted to make sure, haha, but appreciate the "sarcasm" Thanks for the info
Old Mar 31, 2005 | 04:58 PM
Hawkcmc's Avatar
Can you use LED's to make headlights then? You would need to make a fixture with a mirror right ?
Old Mar 31, 2005 | 07:50 PM
The Professor's Avatar
so which LEDs did you buy? when i got mine like a year ago, no right angle LEDs were available. i ended up getting something like this:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
because they have LEDs on the sides too. they look fine at night but they're extremely hard to see during the day.
Old Mar 31, 2005 | 08:08 PM
MetallicaMatt's Avatar
I don't see how LED's could drain a car battery unless your REALLY trying lol
the LEDS i ordered draw like 6 microamps....which, its .0000000006 amps, for you none engineering types
so, i wouldn't worry. if you don't forget to turn off your lights that often, you'll never have a problem with LEDs IMO
Old Mar 31, 2005 | 08:13 PM
VSGLS1's Avatar
.000006 amps is 6uA. Thats nA.
The LEDs will give off less heat on top of the other benefits, so no melting the harness/housing.
Old Mar 31, 2005 | 08:51 PM
04BlackGmc's Avatar
Pretty much they draw next to nothing..
Old Mar 31, 2005 | 08:53 PM
LS1_2NV's Avatar
I got the "Wedge Matrix 25 LED" . They have LED's on the top and on the sides...
I also got the 194 bulbs too."Silver Chrome (amber)"
Old Mar 31, 2005 | 08:56 PM
AW/whiteZ-28's Avatar
http://autolumination.com/images/aut...matrix_dwg.jpg
Be sure to post up how they work out for you I bought some that didn't have the sideways leds and they were not bright at all.
Old Mar 31, 2005 | 09:06 PM
those are the exact ones i got. not the brightest but i didn't want the OEM bulbs to warp the housing and cause leaking.
Old Mar 31, 2005 | 10:33 PM
LS1_2NV's Avatar
Figured they probably wouldn't be as bright, but not too worried about it. I'll take lower heat and extended life over brightness any day!
Old Mar 31, 2005 | 11:11 PM
Flawless02SS's Avatar
I have a LED in my 3rd gen camaro that burns non stop, no dead battery going on 9 yrs now!!
Old Mar 31, 2005 | 11:21 PM
VIP1's Avatar
Copy & Paste Moderator
If I remeber correctly the Cadillac Sixteen actually had LED headlights. They used prizms to focus/aim the light. Eventually all bulbs in a car will be replaced with LEDs. You wont see LED headllights on the market for a while though.
Old Apr 13, 2005 | 04:45 PM
LS1_2NV's Avatar
Here's my smoked/clear corner installation with LED's for those that were interested...
https://ls1tech.com/forums/wiring-stereo-electronics/305740-smoked-clear-corners-led-s-installed-pics.html
