didnt get all the swirl marks
I have a few scuffs from passerbys that the IP and an orange pad will not get out, although not completely through the clear.
You might try some 3M Fine Cut Rubbing Compound.
try to get a nice angle shot too.
and wash the car, then wipe with 50/50 alky/water and that should remove old wax, or any amount of polishing will remove it too...
Wash it, hit it with the IP on an orange pad (PC speed 4-4.5) wipe off any residue with a 50 50 alcohol water mix and see if the swirls are gone, then use the FP2 on a blue pad wipe down the whole car with the alc water mix inspect the finish (and if satisfied) and top with your favorite wax/sealant
Mine's a DD so it'll never be perfect, but I got rid of 90% of the swirls with the above process
Good luck
That's after the FP and the FMJ
Here's an shot down the door (shows the side molding removal)
im on a 6" plate with 6" orange non contoured pad, and 7.5 contoured edge pads. are you going with lake country or what pads?
