Will 500 degree caliper paint hold up??
i used regular duplicolor spray paint not high temp or anything and it has held up perfect for over a year. i guess it depends more on what you are doing with your car though. if you are autocrossing then you will need a high temp for sure because they will heat up more.
I am fairly certain that the 500 degree paint, engine paint and acrylic enamel are all the same bird. I have used acrylic enamel on engines in the past and it held up great. I believe that the engine paint is acrylic enamel.
I painted my calipers with dp-90 epoxy primer, red base coat and clearcoated them, just like if it were a door or bumper. They are holding up great!!
The most important thing is that what you are painting is clean and free of grease etc..
Originally Posted by Nine Ball
I used engine block paint.
