Corvette steering wheel???
Old May 18, 2010 | 07:41 PM
  #101
rabbit320's Avatar
bump! g6 or solstice i say... for a t/a...
Old May 18, 2010 | 09:23 PM
  #102
kain01's Avatar
Originally Posted by LT4vert
So ok , heres the skinny . The C5 and C6(05 4 spoke and 06-up 3 spoke) use the new smaller metric diameter splined shaft in the steering column . The F-bodies used the older than god himself larger splined upper shaft . If your not skeered to disassemble the upper portion the steering column , the new shaft installs in the f-body column just like old one . So Yes it is possible to use a 3 spoke wheel or c5 wheel . You wont however get the 3 spoke radio controls to work . They dont do as much as old ones did because GM bundled in the info center controls in the newer cars , so they only allow for volume up/down , seek up/down and 1 or 2 other things . The voltage outputs are different as well .
Hey just noticed this, so an Impala or Monte Carlo steering wheel would work for us Camaro guy's.
Old May 19, 2010 | 09:57 PM
  #103
rbaksi's Avatar
bump for a g6 or solstice wheel for a T/A as well. I would probably buy one depending on price.
Old May 20, 2010 | 10:38 AM
  #104
Killer_Z's Avatar
I would love to swap out the stock wheel for a 3 spoke vette/cobalt/hhr wheel been thinkin bout it for a while now. seen pics but no info
Old May 20, 2010 | 01:04 PM
  #105
disc0monkey's Avatar
Originally Posted by disc0monkey
guys im working with this^^^^^guy to make a plugnplay setup so you wont need to be changing out your column or anything. Before we get involved in this we wanted to see what kind of interest is out there.
trying to get a easy swap going for us but seems to be no interest
Old May 20, 2010 | 05:06 PM
  #106
LT4vert's Avatar
Yep ....the 2000-2002 Camaro wheel and airbag came directly out of the 95-99 Monte Carlo /Lumina .
Just FYI on fabbing a plug n play airbag . I would seriously avoid that . If someone got into an accident and it didnt go off , you are open game for all kinds of lawsuits because its against the law to modify an airbag in any way shape or form and all the disclaimers in the world would not protect you .
Plus with GM's newer style can bus electronics , I doubt a straight voltage signal like the F-bodies had would even fire it . Almost everything in the new GM cars are a pulsed signal . And the bags in question are multi stage , meaning different signals fire the bag at different blow rates .
Old Aug 20, 2011 | 07:43 PM
  #107
Floorman279's Avatar
more resurectiong......ok dont laugh if im wrong but is this the shaft that you gotta swap over to the fbody?
http://cgi.ebay.com/ebaymotors/97-04...item1c178e2133
Old Aug 20, 2011 | 07:45 PM
  #108
or is it this
http://cgi.ebay.com/ebaymotors/Genui...item3a50476149
Old Aug 20, 2011 | 08:59 PM
  #109
TransAm98's Avatar
You need the shaft in the second link. For anyone considering doing this here is a useful link on rebuilding a GM steering column.
http://www.diyfiero.com/dropspot/Jaz...ck_Rebuild.pdf
Typical GM column. Ours are similar except with the airbag. I took my time and did it in 3 hours including removing and installing the column in the car.
Old Aug 20, 2011 | 10:27 PM
  #110
wait you swapped the wheel in 3 hrs? to swap the wheel, how hard is it to do? do i need anything else besides that shaft and the corvette wheel/airbag??
Old Aug 20, 2011 | 10:57 PM
  #111
TransAm98's Avatar
Exclamation
Steering wheel, airbag and the shaft is all you need. Basic tools, and a few specialty tools which are readily available at a parts store. Yeah, it took me 3 hours, but i removed the entire steering column from the car to do it. Didnt look like it was possible to do in the car. Hardest part for me was getting the high beam switch rod to stay in place while installing the lower steering column housing. Also have to modify the horn wiring and do some minor drilling on the new steering wheel. It sounds more complicated than it really is. The link I gave will be your friend
Old Aug 20, 2011 | 11:20 PM
  #112
ok well i looked at the link......which step do i start at?
Old Aug 20, 2011 | 11:32 PM
  #113
TransAm98's Avatar
Basically I used it for visual references. Once I got the original wheel, airbag and clockspring off I started my teardown on page 59 of the article and work up to page 19. Then followed it in the correct order to put it back together. Disregard pages 39-41. The wiper switch can stay in the housing.
Old Aug 21, 2011 | 09:34 AM
  #114
okv thanks man......appreciate it.........and fineally, this thread can be laid to rest 6-7 years later, that we found a way to put a c5 wheel in an fbody.......now close it lol
