Light bulb in steering wheel..
Old May 26, 2005 | 05:26 PM
FIREHAWK #07's Avatar
Default Light bulb in steering wheel..
The light bulb in my steering wheel went out; the one for the radio controls??? Can somebody please point me in the right direction on how to change it out...
All help is appreciated..... Thanks
Old May 26, 2005 | 09:23 PM
98BlkBrd's Avatar
TTT-----I too would like to know.
Old May 26, 2005 | 10:35 PM
2K2WS6TA's Avatar
The bulb isn't available seperately, it's an all in one assy, close to $70 from the dealer, look on ebay or the local junkyard for a replacement (unless of course you're handy with a soldering iron) pry off the cover of the control (small screwdriver), and replace the board
You can also try to contact T/A fan dan, he has DIY instructions on how to replace the bulbs (dunno if he's still an active member or not)
Old May 27, 2005 | 01:23 AM
damn... i just called by local dealership and they want 141$$$ for the damn thing... id rather have it broken....
Old May 27, 2005 | 01:29 AM
MidNtBlueBatmobile's Avatar
i actually have am EXTRA set if you want, there kinda worn away, i just replaced my radio control buttons.... but they light up none the less....
Old May 27, 2005 | 02:32 AM
evilbadz's Avatar
Just grab some high output white LEDs and some resistors and use those.
I have replaced almost every light in my car with 1 or more 20k mcd LEDs including toggle buttons, door handle lights, ac/gauge cluster/light switches etc.
It all looks better anyway, nice shade of white/blue instead of crappy yellow.
Old May 27, 2005 | 08:54 PM
Danny2tek's Avatar
$15 from Trans Am creations ....http://www.tacreationsusa.com/steering_wheels.htm
Old May 27, 2005 | 09:00 PM
JasonWW's Avatar
Here's some info on fixing it.
http://www.ls1.com/forums/showthread.php?threadid=41179
http://www.ls1.com/forums/showthread.php?t=507275
http://community.webshots.com/album/66665741JDsfSI
Old May 30, 2005 | 11:39 PM
thanks for the help every one...
Old May 31, 2005 | 09:48 PM
NoTicketsPlease's Avatar
Okay, I popped out one of the steering wheel controls and I can only get it back in if I leave it unplugged. It seems impossible to plug the wire back in since it is so short. If anyone has done this, did you plug in the circuit board with it in the control housing or out of it? How did you do it?
Old Jun 1, 2005 | 02:26 AM
GoldenBird's Avatar
What a second...those radio controls light up? Is this the case on all F-bodies with steering wheel controls?
Old Jun 1, 2005 | 07:19 AM
JasonWW's Avatar
It should be. Otherwise, how would you find the right button at night? GM has lights on all the wheels I've seen. Trucks and cars.
If you have a 98+ F-body, then definately.
Old Jun 1, 2005 | 07:21 AM
JasonWW's Avatar
Did you move the airbag out of the way?
Try contacting 98 snake eater. Here is still on these forums.
https://ls1tech.com/forums/member.ph...oster&t=329040
Old Jun 1, 2005 | 09:34 AM
I did not take the steering wheel apart at all
Old Aug 18, 2013 | 04:25 PM
Jeff Gillette's Avatar
New guy here but, Just wanted to jump on here and thank everyone who contributes to this forum. Just purchased a 95 ls1 ta. Love it but, being **** I had to de-bug it a little. And thanks to you guys it wasn't bad at all. I just wanted to point out a couple things that seemed to have some misconceptions. First I had to change out the lights on my steering wheel controls. That module pops right out with some gentle pursuation. No messing with the air bag or anything else. The soldering is a bit tricky (due to how small the bulbs are). The bulbs you are looking for are available at Radio shack for about 2 bucks Part #272-1154, 12v bi-pin lamp. I saw a couple of post that folks claimed getting the plug back in was impossible... Hold the little bastard at the very rear with a small needle nose plier and push the module back onto it. 10 seconds. On a separate note. Who came up with that skip shift thing? What a POS. Took your guys advice and went back to radio shack and picked up part #2711121, 2.2 kohm 1/2 resistor and installed it per one of you threads. Works perfect.. The bad, you have to buy five of them. The good, 99 cents. Anyway, wanted to thank you guys for the education.. I'll be back!
Old Aug 18, 2013 | 07:51 PM
JasonWW's Avatar
For those that have traction control and always have to turn it off, you can buy a programable relay for about $30 and have it press the TC button automatically after a time delay. You don't have to even think about it anymore.
The advantage over just pulling the fuse is that if it's rainy and you want to turn it on, you just push the button from inside.
