wet sanding and clearing tail lights
Old Jun 6, 2005 | 11:38 AM
HAWK#549's Avatar
Default wet sanding and clearing tail lights
Whats the procedure for wet sanding and clearing tail lights? What grit sandpaper and how many coats and such. Does it look nice compared to factory? Thanks fellas.
Old Jun 6, 2005 | 11:58 AM
GrnDragon's Avatar
If I remember correctly I used 1200 grit to scuff up my taillights (with water)and then placed, I think, around 500 little hexagon stickers over the red parts and my dad sprayed my taillights with the car, then he applied around 6-7 coats of clear (but he likes to go heavy to give room to wet sand). I think they turned out pretty nice...
Attached Thumbnails wet sanding and clearing tail lights-smaller_backofcar.jpg
Old Jun 6, 2005 | 12:18 PM
stryker14's Avatar
Im not so sure 1200 is rough enough for the clear to have something to hold on to. I would recommend hitting it with 600-800 and then applying your clear.
Old Jun 6, 2005 | 01:28 PM
PontiacFan's Avatar
Send'em to me, ..., I'll wet-sand & polish them to look like new again! (For a small fee of course!)
No, seriously, I've done it many times. I've done many, many center sections over the last couple years also. Selling them on all the forums & eBay.
Wet-sand with 1200, then 2000 grit. Polish.
(I use a 1/4-sheet sander, & an old B&D orbital polisher with Zaino plastic polish to do the trick. Excellent results.)
Good Luck!
(Uh, I'd not recommend the clear-coat paint thing myself. But I guess that's because I've never tried & simply have better luck wet-sanding & polishing.)
Old Jun 6, 2005 | 04:06 PM
AW/whiteZ-28's Avatar
I just sanded them smooth with 800 and shot clear on them. When I finish with my little "secret taillight experiment", I'll post pics. It's hard to explain but I think it will go well with my berger panel.
Old Jun 6, 2005 | 06:54 PM
Stangkilr's Avatar
Just wet sand them and polish. They will look better than new.
Old Jun 6, 2005 | 08:56 PM
ZEEMAN's Avatar
what about procedure with vht nightshades? clear over that?
Old Jun 6, 2005 | 09:00 PM
OneMeanZ's Avatar
Yep, I did it do mine....wet sanded with 1500 then polished it up........looked good.
Old Jun 6, 2005 | 10:27 PM
sercastiK's Avatar
do it just like paint, do it 600 wet, dry it and clear the **** out of em..I like "concept" clear...
J
Old Jun 7, 2005 | 12:25 AM
jaljohn's Avatar
when you guys say wet-sand do you just mean run contant water while sanding or what?
Old Jun 7, 2005 | 12:29 AM
stryker14's Avatar
Yeah they sell sand paper specifically made for wet sanding. soak the paper for about 10 minutes in water and some ivory dish washing soap and go to town. Might have a water bottle on hand with the same soap/water mixture so you can speed up the process.
Old Jun 7, 2005 | 12:40 AM
'Trust''s Avatar
I wet sanded mine w/1500, then wet sanded w/2000, then polished w/a buffer, then by hand every month to keep em up, good luck!
Old Jun 7, 2005 | 11:03 PM
JAvenger007's Avatar
Well i found my weekend project
Old Jun 8, 2005 | 07:45 AM
HAWK#549's Avatar
haha yeah.......that and getting the lower part of the bumper painted.
Old Jun 9, 2005 | 09:08 AM
ZEEMAN's Avatar
where do you find wet sand paper? i found regular 1500 and 2000 at pep boys but no wet! and also what auto parts stores carry VHT nightshades?
Old Jun 9, 2005 | 10:43 AM
HAWK#549's Avatar
I got the 3M sandpaper, its called wet-something, but you have to add the water yourself. Its regular, dry paper at the store. Those grits are good, but they are more for the finishing coats.
