Question for painters about berger panel
Old Sep 22, 2005 | 10:24 PM
SIK02SS's Avatar
Default Question for painters about berger panel
Well, obviously I decided to do the Berger panel, but like a few others have done I'm going to fill in the Camaro (i figure if someone doesnt know its a camaro already, they dont need to). I'm planning on filling it in with a fiberglass filler instead of bondo for obvious reasons. I'm not the type of person that likes to do things half assed, so; 1) What fiberglass filler should I get and from where? and 2) Do I need to add any flex additive for extra support, or is that just on polyurethane type materials. And yes I will be primering it and doing a whole lot of sanding.
Thanks in advance,
Chris
Old Sep 22, 2005 | 11:42 PM
SIK02SS's Avatar
anybody?
Old Sep 22, 2005 | 11:54 PM
paspar2's Avatar
It should be stiff enough... Don't know where to pick up the fiberglass though sorry...
Hey could you pm me a pic of your taillights? I'm thinking about a set of the altezza... want to see some different types..
Old Sep 23, 2005 | 12:02 AM
SIK02SS's Avatar
thanks, pm sent
Old Sep 23, 2005 | 10:48 AM
SIK02SS's Avatar
nobody knows where to get a fiberglas body filler?
Old Sep 23, 2005 | 12:20 PM
Z'mnypit's Avatar
His sig says export taillights. Those are far from being altezza's.
Old Sep 23, 2005 | 12:22 PM
My2ndls1's Avatar
I know that Wal-mart, autozone, advanced auto, etc. carry a fiberglass repair kit as I'm sure Lowe's, home depot, etc. would. Also any boating supply store should have it. Hope this helps...
Old Sep 23, 2005 | 12:31 PM
Cop Car's Avatar
i just got it at the local car quest becuase they carry paint there also
my suggestion to you would be to get a second pannel that you can paint, so that if you want to sell the car or get tired of it you can put the orginal pannel back on there
thats what i did at least
Old Sep 23, 2005 | 01:28 PM
SIK02SS's Avatar
alright thanks for the info
Old Sep 23, 2005 | 01:39 PM
parbreak's Avatar
I would be inclined to use a product called Dynalite Plastic filler. It's more flexible then Bondo could ever hope to be. After the initial fill and sanding use will most likely have pinholes so I would use a glazing putty in 2-3 steps gradually feathering out each layer until super smooth.
Bryan
parbreak
Old Sep 23, 2005 | 04:30 PM
SIK02SS's Avatar
where can i find that at? and whats the difference between using this stuff compared to a fiberglass filler?
Old Sep 24, 2005 | 12:35 AM
ritchie's Avatar
Your best bet is to get your fiberglass filler from an auto body supply store. I bought the short strand fiberglass filler and it comes with a tube of hardner. I think I paid about $14 tops. I filled in the rear CAMARO letters with the fiberglass filler, then smoothed over it with regular bondo type body filler. It took me a few days to get it as smooth as possible. (I wanted it damn near perfect)
I don't currently have any pics because the car is in the process of being repainted completely.
Hope this helps.
Old Sep 24, 2005 | 08:01 AM
badride5's Avatar
You can get it at Advance:
http://www.partsamerica.com/ProductD...partnumber=272
I don't like it myself. The strands make it very difficult to finish but if you do it like ritchie recommends that will werk.
Old Sep 24, 2005 | 12:12 PM
SIK02SS's Avatar
thanks a lot guys
Old Sep 24, 2005 | 01:07 PM
AntiVenom06's Avatar
I use a commercial fiberglass filler made for building tables, benches etc. So its meant for the weather and abuse already, plus once this stuff gets hard it is stronger than the rear piece itself. It sands down even and smooth with the rest of the panel pretty easy too. You can't even tell there was letters there on everyone I have done.
Old Sep 24, 2005 | 02:48 PM
SIK02SS's Avatar
where would i find that? like home depot or somethin
Old Sep 24, 2005 | 04:59 PM
That or any fabrication shop
Old Apr 4, 2008 | 05:47 PM
nickp650ss's Avatar
I know I a few years late on this thread but I wanted to know what sandpaper to use. Different types for different stages of smoothing? What did you use to but the filler in with? A plastic putty knife? As you can tell I havent done this before. I will be buying a brand new panel for filling and painting. Thanks for the help in advance.
