trouble installing clear corner lenses
Old Oct 2, 2005 | 01:23 PM
sscamaroburn02's Avatar
Default trouble installing clear corner lenses
I bought some euro clear corner lenses and I am trying to find a way to take out the stock yellow ones. Is there anybody who could tell me how to install clear corners. any help would be great.
Old Oct 2, 2005 | 01:28 PM
98boxer's Avatar
I did them from under the car. Take off whats needed from under the car -the plastic guards- then remove the the clear corneres. It may be easier to remove them then to install them. Also as many have said put a small bead of clear rtv around the clear corners so no water will get in.
Old Oct 2, 2005 | 01:32 PM
Lithium's Avatar
SSU's Drunk Typing Whore
A quick search will give ya the answers you are looking for.
Old Oct 2, 2005 | 02:38 PM
Black Z/28's Avatar
I've done it both ways- from the bottom on my first set, from the top on my second set. Definitely easier from the top. Just remove the headlight.
Old Oct 2, 2005 | 02:41 PM
parbreak's Avatar
Maybe a more complete answer is what you were asking for.
1) Remove the 5 plastic connectors holding the front fascia to the bumper
support. This will allow the front fascia to bend enough to pull the headlights
out without scratching any paint.
2) Next remove the headlights. Unplug electrical connections and all bolts.
3) Remove current yellow/orange lights from the top and replace
with clearcorners. I would suggest you seal the new lights with some silcone around the joints to prevent leakage.
4) Reassemble.
Pretty easy if you do them from the top.
Old Oct 2, 2005 | 02:59 PM
Lithium's Avatar
Here.
https://ls1tech.com/forums/showthrea...orner+write+up
Old Oct 2, 2005 | 07:14 PM
NYC FRANK's Avatar
Talking
I took the whole nose off ! lol. I had no directions on How to Install. I wish I would of found this Website sooner !
Old Oct 2, 2005 | 08:51 PM
Trev_SS's Avatar
easiest to take the headlights out then you have direct ascess to the turn signal
