cleaning engine bay
Old Oct 16, 2005 | 02:54 AM
RAIDER's Avatar
Default cleaning engine bay
since simple green is not getting the bestt reviews, how else do you guys effectively clean an ls1. and sorrounding parts. my engine isn't extremely dirty but can use a nice shiney cleaning. thanks
Old Oct 16, 2005 | 03:07 AM
Brandon Boomhauer's Avatar
https://ls1tech.com/forums/appearance-detailing/159036-proper-cleaning-lsx-engine-bay.html
at the very top of the forum....
Old Oct 16, 2005 | 04:17 AM
RAIDER's Avatar
I was looking for an alternative to simple green, that has got a good review, and pics if you don;t mind.
Old Oct 16, 2005 | 04:42 AM
AncientRgn's Avatar
One word, Zaino. I just purchaced a ton of it and I must say, I am extremely satisfied. The car was looking a bit dull then I put this stuff on and I swear it looks just like a really thick mirror.
Old Oct 16, 2005 | 02:08 PM
Schwindj's Avatar
Foamy Engine Brite
James
Old Oct 16, 2005 | 03:31 PM
parbreak's Avatar
UHHHHHH?? I think he was asking about cleaning the engine bay, not the exterior of the car.
Old Oct 16, 2005 | 03:48 PM
chupr0kabra's Avatar
If you have access to a compressor, get an engine cleaner attachment. Home Depot sells the Husky model (Model HDT132) for about $15. When I'm cleaning my engine bay, I'll fill a bucket with car wash solution and another with clean water. Spray the dirty spots with soapy water, then hit then with the clean water, then you can turn off the feed on the sprayer and blow air on the spots to dry them. If the pressure itself doesn't clean off the spot, grab a rag or a stiff paint brush (Meguiars adjustable detailing brush works well here) and work the dirt loose.
Use common sense, with this. It's high pressure and water, so don't go nuts around the computer, the coil packs, or the battery.
-Mike
Old Oct 16, 2005 | 04:09 PM
https://ls1tech.com/forums/appearance-detailing/395428-little-tape-loom-goes-along-ways-pics.html
done with a mitt and carwash soap..
like 3 months ago...
just water and a towel to clean up...
and thats dirty.
Old Oct 16, 2005 | 04:25 PM
~JOSHUA's Avatar
I use water and a micro fiber towel. Then metal polish.
Old Oct 16, 2005 | 04:42 PM
99huggerorangeZ's Avatar
Originally Posted by Schwindj
Foamy Engine Brite
James
foamy engine brite & cd2 detailer
Old Oct 16, 2005 | 04:55 PM
2K2WS6TA's Avatar
Another vote for the Gunk Foaming engine cleaner
Old Oct 16, 2005 | 06:31 PM
why are yall having to use such badass cleaners?
rare cleaning or what?
I clean under the hood every time i wash the car, takes only a few minutes and helps keep the hands clean when you are working on it, not to mention you can check everything out at that time too...
just wonderin
Old Oct 17, 2005 | 12:32 AM
RAIDER's Avatar
i think i'll use a the gunk foam, i do have an air compressor but will just do it with the foam. thanks for the replies
Old Oct 17, 2005 | 12:38 AM
AncientRgn's Avatar
Oops, my bad. I guess I should sleep more
