installation of clear corner lights
Old Nov 7, 2005 | 01:42 PM
1fastz's Avatar
Default installation of clear corner lights
i just recently bought some clear corner lights for my 98 camaro z28, i was just wondering in order to install them, do i need to remove the front clip? or just the headlight and then install? has anyone installed them yet? need your help, thanx
Old Nov 7, 2005 | 01:49 PM
Ling_650vette's Avatar
Pulling the headlight seems to be an easier solution. You can pull the clip, but thats a huge PITA just for clear corners.
Old Nov 7, 2005 | 02:02 PM
thetastelingers's Avatar
Yep.
1 10mm bolt, and slide the headlight out.
That will give you full access to the clear corner.
Old Nov 7, 2005 | 05:07 PM
unSStoppable's Avatar
When I installed mine i just took out the front headlights. Since they sit right above the turn signals without anything really between them its all the access you need.
Old Nov 7, 2005 | 08:18 PM
LS1 Terror's Avatar
its better to take off the headlight. i had to wrestle them out of there. that was kinda tough. have you put a ny rtv silicon on the edge? where the clear meets the back you should they will leak
Old Nov 7, 2005 | 08:28 PM
USMARINE1108's Avatar
You don't even have to take the headlight out. I got mine from the access panels under the car. That way you don't have to mess with getting the lights to point strait again.
Old Nov 8, 2005 | 07:03 AM
the adjustment is on the headlight assembly that slides completely out of the car. No need in worrying about getting the lights to point straight. They go back in the same place that they came out of.
Old Nov 8, 2005 | 07:50 PM
huh. Guess I didn't look at it close enough. It's still pretty easy from the bottom.
Old Nov 8, 2005 | 08:03 PM
Arachnotron's Avatar
Here is a good write-up:
https://ls1tech.com/forums/showthrea...dlight+removal
Old Nov 9, 2005 | 03:36 PM
steveo346's Avatar
i had a really hard time putting my clear corners lights on and i chipped some of my new paint...it was easy taking the headlights and original amber corners but putting the new clear corners on was a pain....i will be at the ls1 shootout this weekend in san antonio raceway if anyone want to see them
Old Nov 9, 2005 | 04:12 PM
LS69TA's Avatar
Those are a huge PITA. I thought I was never going to get those things put in on my Camaro.
Old Nov 11, 2005 | 08:01 PM
mdsmooth's Avatar
I just installed my clear corners last weekend. And trust me, it's definitely easier to install them from the top. You may have trouble sliding the headlights out because it's a tight fit. But it's still easier then going from the bottom. Patience is the key!
Old Nov 11, 2005 | 09:40 PM
The headlights arent "that" big of a problem tho. Re-install is going to require more patience so you 1) dont scratch your paint and 2) get the rubber seal placed correctly.
And yes, its MUCHO easier to do this from up top. Although I will say bulb replacement was a sinch from below.
Old Nov 11, 2005 | 11:17 PM
sscamaroburn02's Avatar
I went from the top. 1 10 mm bolt. Take headlight out. Be careful not to scratch the paint. You will then have direct access to turn signals. Install mine in like 20 minutes.
Old Nov 12, 2005 | 08:17 AM
jmurray87's Avatar
I just took out the headlights to install my black corner lights.
