Sponsored by: DashLynx
Removed side molding...passanger side glue is stubborn :(
Old 11-12-2005, 04:24 PM
1 BAD BIRD's Avatar
Default Removed side molding...passanger side glue is stubborn :(
Hey guys I removed my side moldings on my TA. Looks great. The only issue I have now is how to get the remaining glue off? The drivers side seems like it will be easy. Only leaving the slight white line on the top and bottom where the molding was. NOW The passanger side? The glue seems to be more stubborn. . I just bought Goo Gone. I a going to try it out but how do I apply it? or rub it off? Can I let it soak in on the passangers side? or isn't that good for the paint? I will clay bar when I am done but t his is way too much to take off that way. BTW BOTH thumbs are throbing from rubbing Any help would be great.
Bob s.
Old 11-12-2005, 04:39 PM
GM Muscle's Avatar
Just rub it on with a Microfiber or cotton cloth. If the goo gone doesn't work hit it with some WD-40. It won't hurt the clear coat. If that doesn't work you'll have to go to an autoparts store that sells autobody supplies and pick up some profesional paint cleaner, 3M makes some good stuff that will cut through anything.
Old 11-12-2005, 05:00 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
theres some stuff called goof off i believe and it works great to remove any glue.
Old 11-12-2005, 08:09 PM
1 BAD BIRD's Avatar
Thanks guys...I am going to try it tomorrow after work. I will keep you posted.
Bob s.
Old 11-12-2005, 08:27 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Use your thumb...its going to be sore as hell though after you are done. But it works. Also some thin fishing line will work wonders...along with a clay bar for whats left over.
Old 11-12-2005, 09:42 PM
GETGONE's Avatar
Goo Gone on a rag and rub. It really depends on how old the glue is and what type it is on how easy it will come off. Goo Gone will take dang near anything off but it dulls the clear as it strips the wax and anything else off with it. Make sure you clean and wax the area when done. WD 40 works well and just leaves some smear marks that will wash right off. Ususally for stubborn glue WD 40 doesn't work that great.
Old 11-12-2005, 09:47 PM
boondiggys's Avatar
get an eraser wheel....it attaches to a drill and literally erases the glue from the surface....just go slow and be careful and it wont hurt the paint...you can then go ahead and use a liquid surface cleaner, something by 3m as someone already said....
Old 11-12-2005, 09:58 PM
LS1 Terror's Avatar
i always use lifter1 bug and tar remover that works wonders they sell it at oreillys and walmart its safe for paint and removes all kinds of thing not just bugs
Old 11-12-2005, 10:51 PM
Dustin's Avatar
forget all of those suggestions and get a clay bar. You will have all of that clue off in about 2 or 3 minutes.
Old 11-12-2005, 11:01 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I'd go with the 3M Adhesive Remover. It works great. I used it to remove the underhood emissions decals on my 'bird. I picked up a can of it at my local Napa.
Old 11-12-2005, 11:06 PM
Lithium's Avatar
Jk
Old 11-13-2005, 05:14 PM
WS-6_2002's Avatar
How did oyu get the molding off int he first place? I'm going to try to take off my TRANS AM molding but don' tknow if I should pry it off or what. Take for any tips.
Old 11-13-2005, 05:15 PM
Lithium's Avatar
Fishing line, or just pull it like I did. Be sure to leave your car out in the sun a bit to warm it up so it comes off easier when you pull it.
Old 11-13-2005, 08:22 PM
1 BAD BIRD's Avatar
DONE! Goo Gone worked magic. Took awhile on the passanger side. But the difference was definately worth it
Bob S.
Old 11-14-2005, 08:27 AM
99FormulaM6's Avatar
can i have the molding...? i need it
Old 11-14-2005, 11:20 AM
1 BAD BIRD's Avatar
Umm sorry man I really didn't pay too much attention to how I took them off so they are not straight at all. THey looked like crap all faded and discolored so didn't pay too much attention
Bob s.
Old 11-14-2005, 11:27 AM
well, they wont be straight, they probably ended up all curled up. and paint doesnt matter b.c i would have to paint then anyway...but if you still have them, id like them....
Old 11-14-2005, 07:38 PM
WS-6_2002's Avatar
How soon do you need it? I might attemp to take mine off and if you want them I'll try to keep them in good condition.
Old 11-14-2005, 07:41 PM
as soon as you can get them too me would be great, but i dont want to rush you or anything.
Quick Reply: Removed side molding...passanger side glue is stubborn :(
