Console Mounted Gauges... Take a Look!
Originally Posted by ABeasst
I'd like one made of ABS plastic personally. If you can let me know
Sent PM's
If you want one, its a first pay first serve basis, as there is a limited amount of material. I have enough to make about 8, 3 are already gone. I will not make anymore after this Friday as I am heading out of town. As a disclaimer, you will need to purchase glue to install it. You will also need some sandpaper to scuff up the console area before gluing, and then a dremel or something similar to grind out the plastic behind the gauge holes. I will make some instructions on how to install it if you cant figure it out yourself. As for the cigarette lighter, don't try to remove it nicely, its an install it once and it will never come back out thing. You need to grind the locking tabs off to remove it.
Originally Posted by Ferocity02
Sent PM's
Sent you a PM...
Sent PM!
As a note, there are more people interested than material avaliable, so if you are serious, pay quickly, as this is a first pay first serve basis. I will not make any after this Friday, I might make some more in the spring. Four are reserved, two say they are going to pay soon, leaving two left. If you happen to pay after they are all gone, I will send your money back. Thanks
Originally Posted by Bad Blu Formula
Gauges look great there man. Boost? Where?
