T/A Hawk HIDs - PICS
For example: "For those who just want HID low beams, you need to get so and so housing and so and so size bulb from so and so websites.
"for those of you who would want HID low beams and hi beams, you need so and so housing, so and so bulb size from so and so websites
"for those of u who also want HID fog lights, you have so and so opions, etc, etc.,
If any of these options are not possible then I'd also like to know that so i wouldnt have to keep wondering "Is it possible to do this..." Cause for the longest time i always have wanted to know a straight up answer to wether or not u can convert all ur lights (hi/low and fog lights) to HID's. I have heard so many no's and a few yes's and its just all so confusing, lol. Sorry for all my noobness, but i have a feeling im not the ONLY one who feels this way. Thanks for ur time.
-Ryan
Very few cars use bi-xenon as they really aren't necessary. Regular bulbs seem to provide the high and wide beam you need. The only way I'd say you might could go with seperate high beam HID is if you traveled a lot of seldom used roads at night. In that condition you could turn them on early and then leave them on. Still, every time a car comes your way you will have to turn them off and then back on and the bulbs will undergo the stressfull high voltage turn-on cycle. Constantly doing this will wear the bulbs out prematurely.
If your dead set on high beam HIDs then get a bixenon projector housing that is already made and sealed and ready to drop in the car. The only one I know of is the Hella 90mm Bi-Xenon HID Low/High Beam Lamps which run $538 each. So that's over $1000, but at least it's ready to go and uses top notch components. Most people just don't want to spend that kind of money. I don't.
If you are very crafty you can take a raw bi-xenon projector and make a new housing for it to be sealed in and be water tight, yet vented and filtered. That's what I'm doing if I ever get around to it. This is much cheaper, but takes a lot of knowledge, research and mechanical aptitude. There will probably be some trial and error as well.
As far as fog lights go, I don't even use them. If you do, then it would be a lot easier to just use a very white bulb in them. Assuming you have a huge budget and can afford the bi-xenons and have another $400 or so for a HID fog light, then you could just run a small low beam headlight as fogs and fabricate a housing of some kind. If you want to buy a ready to go assembly, Hella makes a 50mm projector (2" diameter lens), but they run $384 each for the cheapest which is a high beam, but it should be easy to fab a sheild to make a narrow fog light pattern.
Once you add up all the expense you start to see why most folks do not run all the bulbs HID. So yes, it can be done, but not cheaply. Plus, even the complete sealed assemblies will need to be mounted and adjusted and the wiring done through relays. So even if you could afford all the parts you still need the skill to install it all or else pay someone to do it which adds even more expense.
Hopefully that answers your question.
Edit: Has anybody installed the bosch/rallylights h4 housings yet?
If you want to learn more you can try these sites:
http://faqlight.carpassion.info/index.html
Here are various bulb descriptions:
http://www.danielsternlighting.com/p.../products.html
Bulb specs:
http://faqlight.carpassion.info/special-topics.htm
A public forum to look through:
http://www.network54.com/Forum/216460/
A really good forum, but you have to sign up:
http://www.hidplanet.com/forums/
Bulb specs:
Just remember those are fake hid lights
ANd a **** load less than 350 buckshttps://ls1tech.com/forums/showthrea...hlight=housing
..but with tinted bulbs?
HID low and high.
LED turns and fogs.
http://i18.photobucket.com/albums/b1...5/DSCN2014.jpg
Ya the HID lights are awesome! But i cant bring myself to spend that much on lights.. Id rather buy some go.
You have a link where you got yours from?
