T/A Hawk HIDs - PICS
HID low and high.
LED turns and fogs.
Maybe if the turn indicators were the proper amber color it would look better, but as is, it's not right.
yeah, but i found the yellow not to be very bright when the white is on, so in addition i added a second amber led thats only on with the DRLs and turn signals
This time I installed the harness by splicing into the drivers side butt connector of the factory harness, and it started up fine. One day later, it is doing the same thing as last time. It is flicking on and off. It first flicks off and wont go back on, so I turn the headlights off for a few seconds, then turn them back on, and they are ok. This has happened a couple of times.
I contacted the guy again, and he said to switch the ballasts from one side to the other and see if the problem switches sides. What do you guys think I should do? Can you guys show me exactly were you tapped into the factory harness? thanks
If this is not your setup, then please describe your wiring.
http://faqlight.carpassion.info/headlamp-harness.html
In reference to your setup Transamin00, how were you able to pull off the use of High and Low beam HIDs? I recall a post in this thread from JasonWW where it is not done typically due to firing time of the bulbs and stress on the system. They system looks good. JasonWW, so is there a good way to be able to have both High and Low Beam HIDs? I've haven't been following this thread. Trying to bring myself back up to speed. HIDs and blue LED mods are in the planning stages for the car this coming summer. Has anyone come across a good HID fog light kit for 00-02 TAs? I saw LEDguages.com's post about his kit that uses the existing housing. I'm looking for a kit to replace the stock housing (keeping the OD of fog light close to stock). Any suggestions on both systems. Thanks for the info and ideas for modding. Dave
Below are some Bosch E46 bi-xenon projectors.
The advantages od bi-xenon in general are that both high and low beams occupy the same space and only one bulb and ballast per side is needed. So you save space and money.
If you're interested in becoming a sponsor, please send a PM to Pro Stock John or Nine Ball and they will hook you up.
Its in the Hall of Fame sticky and in my sig.
Here is a link for convenience:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
