T/A Hawk HIDs - PICS
Old Dec 11, 2007 | 12:17 AM
  #221
BlacKBirD25's Avatar
pm me, i wanna set
Old Dec 13, 2007 | 01:25 AM
  #222
bmxer8699's Avatar
can i get a pm also, my stock headlights suck terribly.
a pm of where to get them, a link prefebly
Old Dec 13, 2007 | 01:26 AM
  #223
Camaro396's Avatar
I got that same kit for 100 shipped. their nice.
Old Dec 26, 2007 | 10:59 PM
  #224
00badfnta's Avatar
I have the H4 kit for my car now how do I rewire it for the hid conversion?
Old Dec 27, 2007 | 07:00 AM
  #225
InfiniteReality's Avatar
Get some new housings for the H4 kit
Old Dec 27, 2007 | 05:28 PM
  #226
00badfnta's Avatar
I have this H4 kit. So what wire do I cut and then connect to what wires? Not real concern about the highlight situation. Or im I better off just exchanging it for the H7. H7 HID kit does it require cutting of wire too or is it plug-n-play. And the directions sucks.
KYO Plug-N-Play Heavy Duty Wire Harness Upgrade Kit (Model H4)
Description: Protect your car's factory headlight connector from melting with aftermarket halogen light bulb upgrade.
Part #: KYO-PNP-WH-H4
**click image to make bigger**
Attached Thumbnails T/A Hawk HIDs - PICS-hids-001.jpg   T/A Hawk HIDs - PICS-hids-002.jpg   T/A Hawk HIDs - PICS-hids-003.jpg   T/A Hawk HIDs - PICS-racinglab_1981_164290408.jpg
Old Jan 17, 2008 | 10:08 AM
  #227
1MeanTA's Avatar
hey guys...i have been tryin to find a good HID kit to put in my WS6 and im at work while reading this so i dont have time to check out the whole thread, but LEDgauges.com sells a trans am HID kit with the housings included...just in case some of u didnt wanna mess with buying everything and putting it all together...if anyone has it or has suggested it, sorry for the repost....
PS...if anyone does have the setup from them, are u happy with it???
Old Jan 17, 2008 | 01:48 PM
  #228
Runn's Avatar
Looks good
Old Jan 17, 2008 | 03:34 PM
  #229
IMO, I'd buy the name brand Bosche housings & HID kit off ebay. Total will be around $220 for both and you'll have a better cutoff and not blind oncoming traffice as much. Just my .02 since I've had both different setups.
Old Jan 17, 2008 | 06:09 PM
  #230
letsrun97z's Avatar
yep anoter on buying from LEDGAUGEs.com i ordered mine 350 shipped
Old Jan 18, 2008 | 09:24 AM
  #231
1MeanTA's Avatar
LETSRUN97Z---seem to be a good quality product?
Old Mar 31, 2008 | 01:51 PM
  #232
firechicken99's Avatar
does anyone know which bulb the eurolamps housing for the ls1 T/A uses? is it H4 or H7???
Old Mar 31, 2008 | 10:57 PM
  #233
im pretty sure i read it uses H7 but not positive,
Old Apr 1, 2008 | 09:11 AM
  #234
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by JasonWW
These are both dual filament, so neither. I'll try and find out what bulb it uses.
EDIT: Post #1 says he's using H7, but our housings never used a dual filament bulb.
H7 is single filament.
I also know from experience. My mother's 2004 Sonata uses them and I made my own conversion housings once.
Old Apr 1, 2008 | 10:02 AM
  #235
JasonWW's Avatar
That's was my first thought, but I wasn't sure, so I googled the H7 and saw a dual filament bulb. I remember the GTO's used H7. Hell, H7 is what I converted MY TA housings to (I just forgot). Stupid Google. I should have looked at several pics before assuming the 1st image was correct.
So the Eurolamps housing should be H7.
Old Apr 1, 2008 | 12:32 PM
  #236
Eurolamps is H7, Bosche housings are H4s...
I've had both in my car. Bosche are 10x better than the shitty Eurolamps, there's no contest to beam pattern and cutoff.
Old Apr 1, 2008 | 01:33 PM
  #237
The Alchemist's Avatar
UNDER PRESSURE MOD
So where can you buy the Bosche housings? PM me if you don't want to post the link.
Old Apr 1, 2008 | 02:21 PM
  #238
anyone with the site please pm me
Old Apr 1, 2008 | 02:46 PM
  #239
letsrun97z's Avatar
the Hid's for ledgauges.com fit perfect took about 45 min to install very simple to hook up.. everything is inc i can actually see at night now. and i havnt been flashed once i also have mine pointed way down and there still hella bright
Old Apr 3, 2008 | 08:15 AM
  #240
the only thing i dont like about the bosche is that you gotta spend 250 on the lamps and then another at least 150 on the bulbs.
