T/A Blue Odometer
http://chem.csustan.edu/JTB/HELP/COL...el-numbers.gif
I think it's yellow and green that make blue. It's been a LONG time, so not really sure though.
I have almost everything in my car converted to blue LED's from superbrightleds.com except for the headlight switch. For that I got the LED from LS1_SS. I still have to do the steering wheel, ASR, and fog light buttons as well as the odometer.
Here's what I'd get for LEDs
50 3mm blue LEDs
50 5mm blue LEDs
100 5mm white LEDs
Plus you'll need the resistors, jumper wires and circuit board. for interior lights. Only resistors for dash lighting.
I've been buying my LEDs from this place lately. VERY quick shipping and decent prices. www. ledshoppe.com
I bought the HVAC and headlight switch from a Camaro to do mine, easy as pie swap. If I remember right, to convert every dash light in a T/A the way I did (including price of Camaro stuff and reverse overlay) it was around $80 or so.
Thanks for any help and sorry for all the questions,
Joshua
As for blue gauges yes you would need the camaro face for that....Then replace the bulbs with a brighter blue, if you want a more intense blue....
TA's had digital clusters from 97-02
Also, couldn't you put the reverse indiglo gauges in the trans am?
Joshua
Joshua
I remember reading about swapping a 97-02 cluster in a pre-97 car, but I don't think the electronics worked out right. IMO just leave your stock cluster in there and swap the bulb(s) around the odometer to blue LED replacement bulbs so it'll light up blue.
Yep, you can just install a reverse indiglo camaro gauge overlay on top of yours. Just verify that it all with match up with a T/A cluster. I know 98-02's do.
I have one in my 93
