HELP! Trashed my paint.....
I used 3M swirl mark remover and an 8" buffer. I tried polishing the paint, but no luck, the marks won't go away. Anything short of a paintjob going to help? Thanks guys! I've removed 1500 grit wet sand marks with Menzerna Intensive Polish, an orange pad and my Porter Cable. I'd try that first, but you might still end up having to call a pro.
-Mike
Last edited by chupr0kabra; Mar 2, 2006 at 03:25 PM. Reason: It's spelled m-e-n-z-e-r-n-a, not m-e-z-n-e-r-a
It looks as if you've only scuffed the clear ... if it were base coat it would be a lot darker (clear always apears white, if it's been scratched/scuffed)
I estimate about 10 minutes of decent rubbing she'll be as good as new! (actually, it's be more shiney!)
Autopia.org or detailcity.com and find a pro from there in your area to help you out and there is tons of info there..
