Whistler Headlights
Old Mar 13, 2006 | 06:44 PM
bee-stro's Avatar
Default Whistler Headlights
Does anyone here sell Whistler headlights or offer the service of doing them. I have shaky hands and dont wont risk doing them wrong.
Old Mar 13, 2006 | 06:46 PM
Brian2006's Avatar
that's why you mask everything off.
if you still can't do that then ebay offers them
Old Mar 13, 2006 | 07:08 PM
sills1's Avatar
If you are scared to do it yourself, just buy some that are already done. New Era Performance
Click on the picture when it comes up for a larger picture.
Old Mar 13, 2006 | 07:11 PM
6LITEREATER's Avatar
Where are you located?
Old Mar 13, 2006 | 07:47 PM
bee-stro's Avatar
San Francisco
Old Mar 13, 2006 | 07:51 PM
A-EZ's Avatar
I'm the same way and tried to do mine........the only thing I messed up was when I applied the masking tape I used an exacto knife to cut it. Well when I pulled up the tape it pulled a little bit of the relflective coating off.......If you just take in other people's mistakes, you could pull it off no problem......
Old Mar 13, 2006 | 07:53 PM
sills1's Avatar
Use blue painters tape, masking tape is to sticky.
Old Mar 13, 2006 | 08:05 PM
Z28-CTYHNTR's Avatar
I cracked the housing on mine but thats because I didnt leave it int he oven long enough before I tried to pry off the lense. Fortunately it wasnt noticeable and worked fine until I decided to ditch them for halos.
Old Mar 13, 2006 | 08:08 PM
bee-stro's Avatar
Thanks alot. So what are some of the key mistakes that I should avoid making
Old Mar 13, 2006 | 09:48 PM
Ling_650vette's Avatar
Using too much pressure to pop the lense off the housing is probably one of the biggest. You'll crack it very easilly. Dont be afriad to put it back into the oven for 5-10 minutes longer.
Also use plenty of tape and covering. I made sure to put more than I needed in certian area's, then not using enough.
Even with shaky hands, this is something you should be able to do with ease.
Old Mar 13, 2006 | 09:49 PM
Yeah be careful of that housing its very brittle, or at least mine was.
Old Mar 13, 2006 | 10:18 PM
quiet_storm98's Avatar
the main thing for me was getting the lense off..i had to keep putting it back in the oven...but anyway it is really easy to do
Old Mar 15, 2006 | 12:04 AM
98blackvert's Avatar
is there any custom way to put those in a 1998 trans am
Old Mar 15, 2006 | 12:11 AM
Yeah, put a Camaro front end on it and effectivly create a Cam AM.
