who's got these lenses on with halos??????
whats up guys wanted to buy these corner lenses along with some halos but wanted to see if anyone had this same set up yet? here is the link to see the lenses black euro lenses thanks for any replies.
Im ordering me a pair of those smoked clear corners next chance I get. That will put me onto my 4th pair of clear corners, good thing these things are cheap. lol
Just personally speaking, with the chrome/polish around the lights, and the chrome rims the clears flow perfectly. Unless you've got a black stripe, or some more black going on I wouldnt change the lenses you've got (at least if they're still the same from the pic in sig).
I have some similar ones:
Got them from ebay, but as of now I dont know if I would recommend them or not. At first they fogged up on the inside from temp difference, then they leaked. PITA.
![](http://img.photobucket.com/albums/v334/faaaq/My%20Car/12-25-05_1409.jpg)
![](http://img.photobucket.com/albums/v334/faaaq/HX-332-1546PXB-2C-2.jpg)
I got those too. The lens is clear, not smoked, it's just that the housing is black.
![](http://homestead.com/mannyz28/files/haloclear.jpg)
And yeah, mine leaked too after the first car wash, had to resort to this....
![](http://homestead.com/mannyz28/files/leak.jpg)
By the way, the little bulb plugs into a grey receptacle, I took a permanent marker (Sharpie) and made it black so it won't stick out like a sore thumb
Run a bead of silicone around them and let it dry for 24 hours before you install them. Also, once installed, you might want to put some silicone around the plug that holds the big bulb coz on my set, that plug was really loose fitting into the housing which is where the leak comes from.
Oh, and be sure you seat the big bulb properly, it should click twice, if it doesn't, the bulb will work but will be too close to the bottom of the housing and will cause it to melt. I also didn't use the bulbs that came with the clear corner lenses, I replaced them with Silverstars....they are pricey but much cooler looking![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Manny
Manny
Yeah, I have done all of that. Hell I replied on one of your threads telling you to do that ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I dont know why one of them is leaking like a bitch. I may call the company come monday, and see what can be done.
Yeah man...that was a great idea, worked like a charm. Would have given you credit for it if I would have remembered your name...
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
i got news for you, you can order them, but be prepared to wait because i tried to get the black halos for my car, and no one ever had them in stock. but they really dont look that good i perfer the chrome ones they look clean as hell man.
Originally Posted by ls1/srt
how hard were they to install? I tried taking one out the other day and I couldn't get it out at all.
Yeah they are a pain in the *** to take out, but Ive done it so many times (many flooded clear corners, Im on my 3rd pair right now) that they come out pretty easy now. Ive always just put a little muscle behind it and I bent the little piece of metal (that I believe the fasica mounts to) a tiny bit to get that millimeter of clearance I need to get the edge of the corner lense out.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
so do you pull them out front of the bumper, or through the trap door undreneath, do you have to remove the headlamp and pull them out from the top? please elaborate. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
