What to do in preparation for VHT nightshades
Old 04-18-2006, 09:31 PM
SVT THIS's Avatar
Default What to do in preparation for VHT nightshades
I got my 2 cans of nightshades in the mail today. I plan on painting my lights up tomorrow. Do I need to do any sanding of the lights first or should I just spray away? Thanks
Old 04-18-2006, 09:57 PM
ArcticZ28's Avatar
What lights are you planning to shade? If it's just corners, you'll only need a part of one of those cans. Regardless, in preparation if you're doing your headlights and they're foggy, I'd get a plastic lens polishing kit (I think sonus makes one) and clean them up before applying the vht. If it's the corners, I'd just wash em and wipe em down with some alcohol and then spray away.
Old 04-18-2006, 10:49 PM
SVT THIS's Avatar
I'm doing the tails to match the Berger panel I did, SS L.E.D, rear fender lights and clear corners. I'm leaving the headlights alone, I may polish them and do teh Whistler mod but I don't know.
Old 04-18-2006, 10:51 PM
ArcticZ28's Avatar
If the lights are in good shape (not foggy and a bunch of crap on them), then a quick wash and rub with alcohol should do it. The main point is to make sure they are free of grase and grime.
On a side note, make sure you have your lights side by side when you're doing them so you can make sure they both look the same. Too often people do them separate and find out that they don't match when they put em on. Also, a couple coats will be pretty dark but it's hard to tell it. Try and put them up to your car and look at them from all angles after each coat to make sure you don't overdo it. Just a few tips though.
Old 04-19-2006, 12:08 AM
SVT THIS's Avatar
Awesome I appreciate it. So I WON'T have to sand them?
You also said something about a headlight polishing kit. Where do I get it and what alls involved? I was planning on using sandpaper in this order=100 grit, 200grit, 400 grit, 600 grit, 800 grit, 1000, 1200, 1500, then plastic polish. Would that be enough for the headlights to look clear?
Old 04-19-2006, 12:23 AM
ArcticZ28's Avatar
My bad, it's a Novus polishing kit. Check out the link here, walks you through the whole thing https://ls1tech.com/forums/appearance-detailing/157192-fixed-my-yellow-cracked-headlight-today-pics.html .
Old 04-19-2006, 10:38 AM
cmanz28's Avatar
I just got done doing my front turning signals....all i did was use steel wool and scuff them up, clean with alchol, tape them all off, then clean again and then 2 coats of NiteShades then 2 coates of clear.
They look GREAT TO ME!
Old 04-19-2006, 11:38 AM
SVT THIS's Avatar
Do I HAVE to use a clearcoat? I'm out of money and don't have any laying around. Will I be fine without it? Or at least be fine driving without it for a week or so, then could I get some and put it on later? I'm just ready to paint these bitches up!
Old 04-19-2006, 12:31 PM
mcgodx's Avatar
The clearcoat just makes it shinier. You don't have to.
Old 04-19-2006, 02:28 PM
SVT THIS's Avatar
Well I did it. Did all the lights actually. I went ahead and did 2 coats on the headlights just to clean them up a bit. I did a **** load of coats on the tails, ss led, fender lights and front corners. They are about as black as they can be. Hopefully the lights will still shine through!
Old 04-19-2006, 02:38 PM
Moderator
nhra-trans-am's Avatar
pick up a can of clear at wal mart. It's only like 97 cents a can. It will look better, i used clear on my side markers
Old 04-19-2006, 03:46 PM
cmanz28's Avatar
Not a smart idea to do headlights....someone has done a test. It decreases the output A LOT!!!!!!!!!!!!!!!!!!!!! Almost to the point of not being able to see at night.
Old 04-29-2006, 10:27 AM
BlackHawk T/A's Avatar
What are you guys using for clearcoat?
Old 04-29-2006, 01:21 PM
Want to order Nite Shades today and need to know this. I've been to auto parts stores, and Home Depot and couldn't find any.
Old 04-29-2006, 01:40 PM
cmanz28's Avatar
I just used regular gloss clear from a rattle can....it turned out GREAT!!!!
Old 04-29-2006, 02:36 PM
ArcticZ28's Avatar
Only place you can really get it that i've found is through afterthoughts auto or on ebay.
And the clearcoat doesn't necessarily make it shinier, it's meant to keep the shading from fading through washing and weathering. It will shine it up a bit but if you really want it to shine like a taillight surface you'll have to wet sand with some fine grit paper and then buff it.
Old 04-29-2006, 02:52 PM
But what was it? I'm looking for a name here and that tells me nothing
I looked on Afterthoughts and couldn't find it. I don't even know why they would have it.
Old 04-29-2006, 03:00 PM
ArcticZ28's Avatar
No one's give you a name because it will be with whatever other rattle can spray paint people have. No one rattle can clear is better than another.
http://www.afterthoughtsauto.com/vhtnigpain.html
Old 04-29-2006, 03:19 PM
I know where to get the Nite Shades. I'm looking for a can of automotive clearcoat...wow I thought this was going to be simple
No where I have looked has it, Home Depot, AutoZone, O'Reiley's, and Advance, unless its called something else?
Old 04-29-2006, 03:37 PM
ArcticZ28's Avatar
You're kidding, none of those places has a can of clear coat? You must be looking/asking for something or the people are absolutely retarded. It will be with the rest of the rattle cans. For example, if there is a shelf of them with diff color caps, the clearcoat will be the one with the clear cap.
Quick Reply: What to do in preparation for VHT nightshades
