Grill intall WITHOUT the insert?
Old May 22, 2006 | 07:59 PM
Kewl_Blades's Avatar
Default Grill intall WITHOUT the insert?
Anyone know of a billet/alum/steel grill that DOES NOT require the stock grill insert? I do not want to hassle with drilling or "tie wraps" plus the stock grill is already removed.
LS1 2000 Camaro Vert
Old May 22, 2006 | 08:06 PM
Ell Ess Won's Avatar
Old May 22, 2006 | 08:11 PM
so is that a yes?
or is the original insert BEHIND your black billet grill?
Old May 22, 2006 | 11:34 PM
:bump:
Old May 22, 2006 | 11:35 PM
jbuerke142's Avatar
uhhh.. a billet grille installed over the stock grille looks retarded. you're SUPPOSED to remove the stock grille to install it. and the good ones are going to require drilling
dragonZ28's Avatar
I put my billet grille in without the factory one installed. Just get some black ZIP ties, and route them through the holes in your bumpre cover and around the black sections in between the bars of the grille.
Old May 22, 2006 | 11:51 PM
2002BlackSS's Avatar
Most of the aftermarket grilles are replacements for the stocker. This includes the Stull/Carriageworks billet, SLP, rksport, etc.
Old May 23, 2006 | 12:02 AM
yea, almost all grills are going to require you to remove the stock plastic grill
Old May 23, 2006 | 01:08 PM
Most of the ones I have seen here and other Fbody sites are just inserts OVER the stock and they bolt into the stock plastic cover.
I just called Carriage Works and ordered one..should be here by Friday.
Thankx for all your assistance and input.
