Ready to get serious....
In addition to that, there are some extra steps you can take in keeping more swirls from developing:
I only use 100% cotton (white) towels when washing/drying my car. They get washed in warm water with liquid detergent only and without softener in the dryer. I also cut the edges off and hemmed them up with a serger because the borders were some kind of polyester (a little excessive, yes). The powdered detergents may not completely dissolve in the washer and can scratch the surface.
Don't use towels that are dirty, old socks, etc. when washing, but I'm sure you know this. If you drop it, stop using it. When drying, if you notice dirt on the towel, stop using it (you could probably wash that spot again too).
It is unreasonable to try to remove swirls from your finish without some kind of buffer; it would just take too long. The PC is a good tool and you basically can't damage the paint unless you use it without a pad or stick sand paper on it or something retarded. Even on the max setting with a lot of pressure, you won't remove that much clear so the likelihood of you burning through the finish is slim to none. A rotary buffer is a different story, though.
When removing scratches you are basically taking a little of the clearcoat off to make the surface flat again. This is where the different cut compounds/pads come into play.
If you are interested I could probably get some video of "proper" usage of the PC so you could see how to do it. There are some references on the Meguiar's site as well.
Sprayed: Sugarland isn't that far away. I could get together with you some time and let your try out my PC and see how you like it.
-Mike
I was a complete newb at detailing, (yes I used dish soap and and an old t shirt, not on the T/A tho) now I get alot of Wow that's a beautiful black car, I credit autopia, this forum, Menzerna polishes, and the PC for those comments
IIRC autopia.org has a video/pictures of what the Menzerna polishes should look like at various stages, you might want to head over there and check out their forum (you'll learn more about detailing a car and the products to use than you ever wanted to)
The PC is completely safe for anyone to use. Because of its orbital motion, it cannot generate any appreciable amount of heat (which is what damages paint).
You can pick up the PC 7336 from Lowes for under $100 most of the time. There are several great places to order pads, polishes, towels, etc. I like to use www.pakshak.com - Ranney is a great guy to deal with.
Once you get your paint in great shape, it's *very* important that you use proper supplies and techniques for maintenance:
Basic Weekly Wash Supplies
Wash Mitts - Eurow genuine sheepskin mitt or a 100% cotton wash mitt.
Car Wash Soap - some popular ones are Eagle One Wet wash, 1Z Perls shampoo, Zaino Z7, and Wolfgang auto bathe.
Drying - Waffle Weave microfiber towels, electric leaf blower, and/or 100% white cotton towels, made in USA.
Washing, Drying and Waxing Tips
- Never use circular motions. Always wash, dry, and wax using front to back and top to bottom motions.
- Don't use the same mitt or bucket for wheels that you use on your paint. The brake dust, etc. from your wheels will cause scratches and swirls in your paint.
- Use two buckets for washing paint. One with a soapy mixture, the other with plain water to rinse the mitt between panels.
Caring for Mitts and Towels
- Wash on the Hot/Cold setting
- Use liquid detergent only w/ no bleach and NO fabric softener
- Add distilled white vinegar to the rinse cycle for added softness and soil release
- Rinse twice
- Dry towels on low heat w/ no fabric sheets
These tips will help minimize swirls, scratches, etc.
you mentioned using Meg's #7 . #7 is a high oil content show glaze, that is not designed to last more than a few days, tops..
don't be afraid of the PC ..
That vid will also be a big help
Sprayed: Once you learn to use the PC, you will wonder why you didn't buy it sooner.
Good purchase. I've been taught that you should work with an area of about four square feet; make horizontal passes first, overlapping your previous pass about halfway, then vertical, then diagonally across the surface while maintaining the 50% overlap.
For a while you will probably have to experiment a little to see how long you need to work different compounds into the surface; I usually make an 'X' shape on the pad or, when possible, leave a line across the surface I am intending to work. Using too much of one compound will force you to work it longer (and costs you more money than necessary) while using too little doesn't get the job done.
Arm speed is difficult to express online; that's why I was hoping to put together a video that would give you some idea.
I'm sure others will chime in with what they do. There is a great writeup in the Hall of Fame sticky that you should take a look at (if you haven't already).
