zaino zpc leaveing haze?????
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
hey guys i need some help/
my problem is i tryed useing the zpc that i have with a small random orbit polisher.
i only have the cotton pads for it and i did a section of the hood and it left some haze spots on the hood.
i know i need a porter cable but i cant afford one right now so im trying to use what i have
please help
thanks again
please help
thanks again
please help
thanks again
please help
thanks again
Zaino is very easy to apply and remove by hand and a buffer is not going to save you a huge amount of time so I suggest if you plan to use Zaino do it by hand. Just my opinion.
Originally Posted by Mike02Z
I would not suggest applying Zaino with an orbital but if it leaves a haze then you are probably applying it too thick. Once it dries completly you should be able to get a hazyness off. It can take a few hours to dry and if it's cool a lot longer especially if it was put on thick.
The haze should not be a problem according to Sal Zaino product information frequently asked question about haze on dark colored cars.http://www.zainostore.com/Merchant2/...ory_Code=Zaino
I use Z-PC Fusion frequently & have no problems. I have followed the information in the above link. I would not suggest using cotton pads. I use a porter cable #7424 with an orange pad(abrasive) or white pad.
