Coke Takes Bugs Off! What???
Then wash the car completely, with car wash soap. Claybar the paint after the wash, to remove the tiny, left over stuff that the B&T remover and car wash didn't get rid of.
Then throw a good coat of wax on the car. Meguires NXT is great, I use it regularly, and it leaves the paint extremely smooth. I can throw a dry towel on the hood and it will slide right off the front of the car. Bugs and road grime have much less chance of actually sticking to the paint.
Very true
-Brandon
One of the tricks I use a lot is to soak the bug with a quick detailing spray for several minutes, then try claybarring, and sometimes a little cleaner wax if needed .. just make sure whatever you are using will not scratch your paint, either by itself, or by using the bug guts as sandpaper.
and to clarify on using a clay bar for bugs .. you use it after you have washed the car properly, to remove any remaiing residue. you don't start out with the bar ..
