Used PC to get rid of swirls
Thanks!
You have to let the product break down before that specific spot. IE you need to do small sections of the car instead of doing the whole hood, door, quarter panel... or even an area such as HALF the hood is too big to do all at once. An example would be breaking the hood into 4-6 sections and using a new application of polish in each section, working it until its all broken down BUT not all the way to a dry-buff (dry buff meaning working it until its totally dry).
Good luck.. you should be able to get the job done with the PC and the Menzerna polish.
Good luck.
I am using between 4.5 and 5 on the buffer. I seemed to get the best results with that speed. As for pressure I am pushing down a decent amount definantly not to much but what I seemed to have thought would be enough.
The best grinders feature variable speed, and dials to "set" your max speed.
You can get ANY swirl or defect out at 1400-1800 rpms.
Then, you need 2-3 good quality foam pads, possibly a wool pad-1 each for every step you will need to do- this of course depends on what condition the paint is in.
The only stuff that "truly" works is professional grade material- Presta and 3M are 2 that I like really well. You have to realize that the professional compounds cut and break down into finer grit as the buffer heat and speed move it into the paint- resulting in a swirl free finish. The rate at which they break down, and the "carrying" solution is what keeps the paint from burning and swirling back up. Look to pay anywhere from 35-50.00 dollars for a bottle of Presta or 3M, and you normally will need one for compounding, one for swirl removing, and one for final glaze.
There are some "1 step" compound/finish materials out there that do work for minor imperfections- I just haven't tried many of them.
-Mike
-Mike
Thats why I always recommend someone spend a little more dough and pick up the ones with the speed dials on it.You can always start at the lowest setting and move up as your skills become better.
FWIW you can pick up a nice Hitachi rotary with a good motor, dial adjustable speeds, and pretty lightweight from Coastal Tool for $99 + shipping. Ive heard a lot of good about the Hitachi and will be getting my own soon.
I will almost always grab the PC to fix a defect, prior to breaking out the rotary ..
EDIT: I sounded kind of dick-headed up there. I myself am an avid PC user and even with a rotary, my PC would probably be my first choice. I'm in the same boat as you guys.
