Windshield removal problems...
Old Aug 9, 2006 | 12:38 AM
nokeman's Avatar
Default Windshield removal problems...
So I had an autoglass company come out to replace my cracked windshield and they said they couldnt get one of the wiper blade arms off so they couldnt replace the windshield. Any ideas how I can fix this problem?
Old Aug 9, 2006 | 12:46 AM
infinitebird's Avatar
What you do is:
1. turn the car on and the wipers on, cut off the ignition while they are up.
2. turn car off, rotate them manually down to the bottom of the wiper stroke (but not farther than that, to the off position)
3. take off the bolt, then pull up on the arm and wiggle it sideways slightly while doing that
That's how I took mine off, and it was easy. This was on an lt1 though, so i'm not sure if the ls1s are different. The position of the arm when you are trying to pull it off is important, it wouldn't come off for me in any other position. If they tried to take if off in the full down position, that's probably why it didn't work.
If that doesn't work there is a special tool you can get to pull them off.
Old Aug 9, 2006 | 04:13 AM
shawn's SS's Avatar
Find a new glass company.
Old Aug 9, 2006 | 07:26 AM
keliente's Avatar
No ****. Taking a wiper arm off is not rocket science. Remove the nut and tap the stud with a hammer while pulling up on the arm.
Old Aug 9, 2006 | 07:38 AM
2001chevroletz28's Avatar
I have installed autoglass for 15 years and they just suck man! They can be a bitch but damn that is crazy!
Old Aug 9, 2006 | 09:56 AM
01ls1lover's Avatar
Break the window.. it would relieve stress and its already broke, Problem solved!
Old Aug 9, 2006 | 10:04 AM
they make a wiper removal tool makes it simple they should have had one... I could probably guess which company it was..
Old Aug 9, 2006 | 10:17 AM
nokeman's Avatar
Well they said that they couldnt get the tool on there in the proper angle for the tool to work. It did seem a little rediculous. Anybody have a glass company in Northern VA that they KNOW will work?
Old Aug 9, 2006 | 10:34 AM
just use a reputable company that has trained techs uses good products and good name brand glass. You may check witrh some of the nicer local body shops see who they would recomend to you.Also you always get what you pay for so dont always just choose the cheapest ask questions.
Old Aug 9, 2006 | 10:35 AM
Did the company you tried to use before start with an S ?
Old Aug 9, 2006 | 11:52 AM
nokeman's Avatar
no I dont think so...I think it was an H
Old Aug 9, 2006 | 11:53 AM
nokeman's Avatar
They were located over by Lee highway and prosperity blvd.
Old Aug 9, 2006 | 12:09 PM
nyteryder167's Avatar
When they replaced my windshield, I don't think they took the wiper arms off the car.
Old Aug 9, 2006 | 03:29 PM
nokeman's Avatar
Hmm...I dont know. I thought they always had to remove the wiper arms. Maybe they didnt know what they were talking about. I just called another company and they wanted to charge me $350 for a windshield replacement. Thats a bit high I think.
Old Aug 9, 2006 | 03:37 PM
MrDude_1's Avatar
i concur. i was going to type the exact same thing.
Old Aug 9, 2006 | 06:00 PM
LvDemKings's Avatar
I had a lot of trouble with my pass. side wiper coming off. A battery terminal puller is what got it off though...no problem. Just an idea.
Old Aug 9, 2006 | 07:30 PM
Black Z/28's Avatar
Nokeman,
I had my Dakota winshield replaced last summer in my driveway. I was very impressed with this guy's skill and speed. He had the job completed in less than an hour (no problem with wiper arms). Damned if I can remember the name of the company. I'll look around for the reciept.
Old Aug 9, 2006 | 11:18 PM
nokeman's Avatar
Yeah man try and do that. And let me know how much it was too. I gotta find something quick, as my inspection is running out. Thanks alot!
Old Aug 10, 2006 | 11:17 AM
farnoush's Avatar
Haha dont worry so much about that inspection. I drove around for a month with no front plate, no inspection and no county tag and I had no problems.
Old Aug 10, 2006 | 01:56 PM
your windshield should be around 225 or so intalled and they have to take off the wipers man no way around it.....
