takeing off the shifter knob on a 6 speed
Old 10-09-2006, 06:17 PM
camaro ss02's Avatar
Default takeing off the shifter **** on a 6 speed
i have a 02 ss and that dam thing does not want to come off im sure i would end up breaking it... how do u get that bitch off?
Old 10-09-2006, 06:24 PM
LS1powerhouse02's Avatar
I promise you wont break it! Mine was a bitch too! Just get a really good grip on it with both hands and possibly a rag over it to keep it from getting slippery and twist like a ****!! Mine finally broke lose. If your too weak to get it off like that then i guess you could use a filter wrench or a pipe wrench but make sure you put a rag around the **** so you dont tear it up. Good luck!
Brent
Old 10-09-2006, 08:00 PM
99_Z_155's Avatar
im not sure if thats totally true. if its the stock shifter, you can actually twist the stick out of the molded rubber isolateri youre not careful. it happened to me.
Old 10-09-2006, 08:02 PM
Trev_SS's Avatar
99_Z_155 i did that same thing so i just gorilla glued it back together and the shifter nobe finally will come off
Old 10-09-2006, 08:23 PM
navymitch12's Avatar
grab twist!
that is all!
Old 10-09-2006, 09:59 PM
kraaazymike's Avatar
lefty loosey righty tighty!
Old 10-09-2006, 10:40 PM
onebadblackz's Avatar
what about the c5 stock shifter ****???
Old 10-10-2006, 09:00 AM
WADDISME's Avatar
Just took mine off this weekend to put short stick on. Just grip it and rip it!
Old 10-10-2006, 11:40 AM
ok thank you all ill go try it if i break it im coming back to all of u haha
Old 10-10-2006, 03:36 PM
LS FUN's Avatar
Try to take it off when the car has not been driven for a bit... the tranny stays really warm after you drive the car. We all know metal expands as it gets warmer. Not saying this will solve your problem, but I have realized it to be a bit easier to remove the **** when the car has sat overnight as opposed to right after I drove home. Just my .02
Old 10-10-2006, 08:42 PM
WADDISME's Avatar
If it does break, just repl it with the new Z06 shifter. It looks cool. Someone had a thread about it. Maybe you will get lucky and break it
Old 10-13-2006, 12:20 AM
Camaro Rick's Avatar
I had a hell of a time so I pulled out the smallest strap wrench I could find.
Worked like a charm! Just strap it around and twist it off. Super easy.
Quick Reply: takeing off the shifter knob on a 6 speed
