M6 shift boot on A4 car
Old Oct 10, 2006 | 09:07 PM
1sloLS1's Avatar
Default M6 shift boot on A4 car
i have seen it before on here but now i cant find it...... someone on here had taken the top plate for the console out of a M6 car and said that they modified it to work with the auto shifter, now you lose the gear indicator but it would look damn good with a shift boot around the shifter. if anyone knows what you would have to do to make this work i would greatly appreciate it pics would be nice too
Old Oct 11, 2006 | 08:16 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Here's the write-up I did on both A4 Shifter Mod and Shift Boot:
A4 Shifter Mod/Shift Boot
Didn't use the M6 boot though - found that the one from a Grand Am worked MUCH Better!
-Jay-
Old Oct 11, 2006 | 09:23 AM
jmm98LS1's Avatar
I think what he's talking about is swapping the entire top half of the plastic console from an m6 car. If I remember right, doing so eliminates the ability to shift the car into 1st and 2nd gear manually because the shifter hits the back of the console. Dunno if that's a big deal to you or not. I can't get anything to pull up on search at the moment.
Old Oct 11, 2006 | 03:06 PM
1sloLS1's Avatar
that write up is tight if i want to keep the stock **** will the boot work with it or do i have to still shorten the shifter?????? was hoping that the boot will go over the bottom of the stock ****
Old Oct 11, 2006 | 03:12 PM
1QUIKWS6's Avatar
Well, I don't think the boot will go over the stock **** tail as it is much bigger than the tail on the aftermarket **** - but it is slightly elastic so it might. I can't check for certain as I no longer have the stock ****.
As far as the boot height goes with the stock **** - it probably would come right up to the bottom of the stock tail, but I can't be certain.
Guess I have alot of 'if's' in those last answers!
-Jay-
Old Oct 11, 2006 | 03:43 PM
1sloLS1's Avatar
thanks lot man you have given me hope in making my A4 look alot better
Old Oct 11, 2006 | 03:48 PM
1QUIKWS6's Avatar
No problem! I don't know if you can still find the **** I purchased as it is from MBA and they're out of business. There was a sponsor here carrying the remainder of their stock - so they might still have some available.
I purchased the **** & A4 Adapter that I used from a member here in the For Sale Section.
The combo of the **** I used and the boot was perfect - the boot install was VERY easy with no modifications other than removing the stock plastic sliders.
The pics don't do the setup justice - it looks much better in person
Old Oct 11, 2006 | 07:46 PM
VIP1's Avatar
Copy & Paste Moderator
Here is how I added a shift boot to my A4:
http://www.fadingarrow.com/ShiftBoot.htm
Here is a thread about installing a M6 console in an A4:
https://ls1tech.com/forums/appearance-detailing/532059-fabbing-leather-shifter-boot.html
(I know its a TH400, but scroll down for some applicalbe links.)
Old Oct 14, 2006 | 07:02 AM
Marc 85Z28's Avatar
I've got the M6 upper console on my A4 car. Again, like stated above, 1st and 2nd gear cannot be selected. Additionally, the ashtray (behind the shifter on the M6 console) cannot be opened while in drive, and if the ashtray is open, drive cannot be selected.
It looks MUCH better than the A4 stock console. Basically looks just like an M6 car with a A4 shift handle. I've stood from a distance and watched people argue over whether or not the car was an auto or manual.
Only pic I have that shows the shifter, and its pretty shitty:
I englarged the pic to show the shifter better and its too big for the board, so you have to click (BIG pic!):
M6 console with A4 shifter
Stock shifter BTW.
Old Nov 4, 2006 | 11:22 AM
1sloLS1's Avatar
thanks for the advice on the grand am shift boot!!!!! it is perfect looks factory and it even streched enough to go over the stock shifter handle!!!!!!!!!!!!!!
Old Nov 4, 2006 | 01:34 PM
1QUIKWS6's Avatar
Sweet! Looks good - glad to be of help
Old Jan 12, 2007 | 09:14 AM
Mexicola's Avatar
Default Great info - exactly what I needed
This thread was exactly what I've been looking for. I'm new to the 4th gen world and I figured this was do-able. I had a friend a lonnng time ago that did this in his fox body stang with an AOD. The 5 spd console looked so much better.
Just at a glance, I figured I'd lose the use of 1st and possibly 2nd gear selection and it sounds like that's the case. Now here's the newbie question (flamesuit on) are the lower consoles the same and the only difference is the uppers?
If that's the case, does anyone have a black 98-02 M6 upper they'd like to part with ?
(I'll post a WTB in the parts forum too).
Also, I saw somewhere there was an adapter to fit a M6 shift **** to an A4 shifter, but I can't remember where I saw that and I can't find the adapter after searching a handful of online vendors. Any info on this part would be great.
Thanks in advance-
Old Jan 12, 2007 | 09:30 AM
PontiacFan's Avatar
It was right here, in the post above yours a couple notches.
https://ls1tech.com/forums/showthread.php?t=532059
Old Jan 12, 2007 | 11:30 AM
VIP1's Avatar
https://ls1tech.com/forums/appearance-detailing/476760-automatic-shift-knob-conversion-kits.html
https://ls1tech.com/forums/appearance-detailing/510891-auto-shift-knob-options.html
https://ls1tech.com/forums/appearance-detailing/507571-auto-knob.html
https://ls1tech.com/forums/appearance-detailing/474757-retro-shift-knob-auto.html
https://ls1tech.com/forums/showthrea...&page=11&pp=20
https://ls1tech.com/forums/showthrea...&page=17&pp=20
Old Jan 12, 2007 | 01:11 PM
1QUIKWS6's Avatar
You don't lose ANY gear selection with any of the Shift ****/Boot mods I've seen (including mine that was referenced earlier with link)...
Sent you a PM with link to adapter site
-Jay-
Old Jan 12, 2007 | 01:30 PM
ghettocruiser's Avatar
Hey all... I own a thirdgen that used to be an automatic. Back before I even thought of donig an LS1/6spd swap, I put in a 4th gen manual console. Since the cars are so similar, this will most likely apply to you 4th gen guys too.
In order to have free range of the gear selection, I had to modify things a bit. The shifter is bolted to the floor with 4 bolts. I simply elongated them in the direction that I need it to go. In my case, it was towards the driver and foward. So I made them longer, slid the shifter, bolted it back down, and that was is. I Never had a problem getting to the ashtray either...because thats where my window switches are.
Any of these ideas are good ones though!!
Justin
Old Jan 12, 2007 | 04:11 PM
VIP1's Avatar
-Jay-
He's referring to using the M6 console in place of the A4 console.
Read the threads in my first post.
Old Jan 12, 2007 | 10:53 PM
Marc 85Z28's Avatar
Thanks in advance-
MBA Products made them years ago, but they have since gone out of business and all stock has dried up. Thunder Racing still sells some remainder MBA stuff, so try there.
