Got tired of the orange LEDs in my odometer/trip meter. . .
Old 01-23-2007, 11:38 PM
Duffster's Avatar
Default Got tired of the orange LEDs in my odometer/trip meter. . .
BTW, you need to be VERY careful when disassembling this. . .and soldiering this. . .and reassembling this. . .
Lots of little things you can do wrong, and then, it gets expensive
And then, since I can't leave well enough alone, did the ASR and foglight switch modifications also. Replaced the original bulbs w/7000 blue LEDs. Will have pictures of that later. basically just like the ones on Keliente's site here. . . http://www.keliente.com/switches.htm
Had flash on. . .
Bright little buggars ehh?
Package as it stands currently. . .more to come!
I have no life.
After posting this on a local board last night, had a friend hit me up to do his 99 TA tonight. Did the odo/trip meter swapout in about 70-80 minutes start to finish! TAs are SOOOO much easier than Camaros because of the dash setup!
Old 01-24-2007, 12:03 AM
elanorss's Avatar
Thats tight. how long does it take to do a camaro?? said the ta was quicker. wish i was closer to you. im about 9 hrs away. would love to have that done to my camaro. great lookin change.
Old 01-24-2007, 12:12 AM
Gun5's Avatar
how'd u get your headunit to stick in there straight my kenwood always slides "into" the dash
Old 01-24-2007, 12:23 AM
Ehatcher's Avatar
Excuse me for my ignorance with the camaro guages ... but didnt they have a "film" behind to give the orange glow? or is that only with the T/A? If i am anywhere near correct could you post up on how you removed the film? i read that replacing the bulb wont help. Cluster looks sick though man!
Old 01-24-2007, 08:14 AM
Duffster's Avatar
ElanorSS, took me about 2 hours start to finish for my Camaro having not done it before. The gauges for the TA/Firebirds pops out easier over the column.
Gun5, ALOT of finageling(screwing around w/the fitment and custom cutting a bracket to hold the stuff together). Made a post about it some time ago. https://ls1tech.com/forums/showthrea...hlight=humount
Ehatcher, no film. Orange LEDs w/a piece of frosted plexi. Did a friends T/A last night and had same.
Old 01-24-2007, 08:25 AM
DwDrummer's Avatar
Very nice looking! Good job!
Derek
Old 01-24-2007, 08:40 AM
CJDZ24_Z28's Avatar
always good to see something different
Old 01-24-2007, 09:31 AM
keliente's Avatar
That looks much better!!
Old 01-24-2007, 09:59 AM
High Pressure's Avatar
thats sweet!!
Old 01-24-2007, 10:32 AM
Duffster's Avatar
More to go! YOUR FAULT!
Old 01-24-2007, 11:03 AM
LS1obsession's Avatar
The film is only on the t/a's, and it is only on the actual gauge overlay and not the odometer. You cannot successful remove the film. You can try using acetone, but it will turn out like ****.
Duffster, do you have LEDS in your gauges?
Old 01-24-2007, 11:10 AM
Duffster's Avatar
Not yet. going to go w/blue lights in the gauges themselves.
Old 02-17-2007, 05:44 PM
Dave1970's Avatar
Diffuser,
Just did the odometer LED mod. My odometer lights ups but the mileage and trip numbers are not showing up? Any ideas?
Old 02-17-2007, 05:52 PM
mycamaroSS's Avatar
dude that's tight i might do that tomorrow
Old 02-17-2007, 07:44 PM
Pro-Mo's Avatar
Are there LEDs that can make them "oranger"
Old 02-18-2007, 12:37 AM
Duffster's Avatar
Originally Posted by Dave1970
Diffuser,
Basically, you've probably got the rubber walls misaligned w/the clear glass. If you look at it VERY VERY closely, you can see where the impressions on the rubber are and try your damnedest...(is that spelled right) to realign it. GOOD LUCK!
Take your time, works well. Took me two hours for mine and a night later, about 1 hour for a friend.
I suspect you can get them oranger w/brighter orange LEDs. Good luck.
Old 02-18-2007, 03:19 AM
Camaro Ryder KV's Avatar
duff, simply awesome!
ps
the ground effects are off for the winter, we already had a few bad snows, i am so glad i took em off!
Old 02-18-2007, 12:03 PM
3.8to6.0's Avatar
Is there a write-up for this somewhere?
Old 02-18-2007, 01:04 PM
Dave1970's Avatar
3.8to6.0, Here's some related links for the mods.
http://www.stevendbrown.com/Steering...oControls.html
http://www.ledgauges.com/id26.html
http://www.evlls1.com/interiorlighting.html
http://www.evlls1.com/ls1.html
http://www.keliente.com/LED.htm
https://ls1tech.com/forums/showthrea...=Blue+Odometer
Hope this helps, there's alot of others that you can find using the search with keywords such as blue LEDs, LED mod, Blue gauges, etc.
Old 02-18-2007, 01:23 PM
99zman's Avatar
that looks killer.
Quick Reply: Got tired of the orange LEDs in my odometer/trip meter. . .
