Removed my stock bodykit, need help on removing the black clips
. I just removed my stock "RS" kit from my z28 however, how can i remove the metal black clips (the one that holds the kit to the car itself) away ? It seems like it was permanent drilled on the bottom around car. Thanks in advance
I just removed mine over Christmas. You will need to drill the rivets out with a 3/16" drill bit. Thats all it takes. Best advice is to have a good drill, very sharp bits and try the best you can to get the bit in the center of the rivet. This should minimize the holes in the body work. Feel free to ask any other questions. Good luck!!
