sound deadening
Old Mar 11, 2007 | 05:46 PM
blackbyrd's Avatar
Default sound deadening
i searched but didnt find that many people that did it. was wondering who has and if its worth it??? i was going to do it to my car once the swap is finished mostly because of the stereo but i was curious if it cut down on some the outside noise getting in if so i would like to do it to my truck as well it has some turndowns right behind the cab and on the interstat it can get a little old if you know what i mean.
so whose done it and what where the results post up
Old Mar 11, 2007 | 06:51 PM
schtick's Avatar
I did it to my vette with some stuff like Dynamat that I got from a sponsor on the vette forum. I could tell a decent difference once it was installed but vettes generally have lots of road noise anyway. I think I probably would've gone with a different brand because I don't think it was really that much better than the popular brands for the money.
Old Mar 11, 2007 | 07:37 PM
blackbyrd's Avatar
cool anyone else done the silent mod
Old Mar 11, 2007 | 07:43 PM
00CaliforniaZ28's Avatar
I did my entire car in BrownBread (doubled in some areas), and then did a layer of their L-Comp, which is a much heavier weighted sound reducer, all along my tranny tunnel and in the hatch area. It made a slight difference, but it didn't reduce the transmission/exhaust noise as I had hoped. It did dramatically reduce panel rattling, and the stereo was much nicer sounding, so that was good. However I ended up spending over $500 for it, plus it added ~100pounds to the car. If its a daily driver, itll help a little, but its not going to turn your Camaro into a Lexus or anything. I may just go back and pull out the LComp, since that is where most of the weight is coming from, and then just leave the brown bread. Also remember a lot of the noise you hear when driving is wind noise, so this isnt going to alleviate that at all. But on the plus side I found a few bucks in change from pulling all the carpet out!
Old Mar 11, 2007 | 07:47 PM
69z-28's Avatar
https://ls1tech.com/forums/wiring-stereo-electronics/622232-latest-sound-deadening-pics.html
150 sq feet of Elemental Designs eDead v2
Old Mar 11, 2007 | 09:55 PM
blackbyrd's Avatar
thanks 69z-28 i had a friend with a 95 z28 that had the loudmouth you couldnt talk in that car on the interstate and giving me an actual comparison helps out a lot had a friend with magnaflow on his ta. that was the kinda of info i was looking for preciate it
Old Mar 12, 2007 | 06:42 AM
coolformula's Avatar
I did this. Just got some stuff from ebay. It works pretty good. I lined all under the carpet in the hatch area.
Old Mar 12, 2007 | 07:38 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Dont add weight to the car!!! Nooooooo j/k
Old Mar 12, 2007 | 11:23 AM
ProjectCamaro's Avatar
160sq/ft of sound deadening mat and 6 sq/yds of sound deadening foam.
http://www.projectcamaro.net/forum/s...ead.php?t=8114
Old Mar 12, 2007 | 11:28 AM
The Black Pearl's Avatar
Has anyone heard of B-Quiet? Are their products any good?
Old Mar 12, 2007 | 02:46 PM
BitViper's Avatar
Alot of people are starting to use Frost King..avalaiable at Home Depot...
reduces a lot of the ighg frequency stuff
Old Mar 12, 2007 | 11:32 PM
blackbyrd's Avatar
wasnt that kind of a green shaded foam i think i saw some of that stuff in someones progress pics
Old Mar 13, 2007 | 12:13 AM
You can use the stuff from the home improvment centers but don't expect it to do a whole lot. It's real thin and wasn't made for sound deadening. This is also why you should be careful when buying sound deadening on eBay. There's a lot of people that sell that stuff as sound deadening because it looks like it.
