Window alignment write up
Old Nov 14, 2009 | 09:47 PM
  #41
Engine_HP's Avatar
nice ill do that when i have time.
Old Nov 15, 2009 | 12:34 AM
  #42
TireSm0ke's Avatar
Where did you get the brush assembly replacements? I lost one when some jackass tried to break into my car by popping out the window. Lets just this jackass was unsuccessful... But now im left with a bigger problem: When my window is less than halfway down it slides back and forth freely (towards the front and rear of the car). When the window is going up, I have to guide it with my hand to make sure it slides in the weatherstripping (right near the mirror). Could this be a fix? Or do I need a new regulator?
Old Apr 12, 2010 | 01:41 AM
  #43
01ssreda4's Avatar
good thread....
Old Apr 12, 2010 | 08:51 AM
  #44
whitdog54's Avatar
Thanks for brining this back. Im having the same problem.
Old Oct 13, 2010 | 10:30 AM
  #45
sneaky7980's Avatar
That time of the year again.
Old Oct 14, 2010 | 06:30 PM
  #46
96silverram's Avatar
Nice write-up
Old Jan 16, 2011 | 10:35 PM
  #47
Elthesh's Avatar
I'm sending this back up top. 2 of the rivets holding the regulator broke causing the window to not shut properly. I replaced them with 1/4 inch bolts within hours of breaking, but it still wouldn't seal at the front of the door, passenger side, near the triangle piece. Using this guide, I loosened D and E, pushed D downwards some, tightened up and the window seals perfectly on all sides. So, great write up here!
Old Jan 17, 2011 | 12:58 PM
  #48
sneaky7980's Avatar
Glad to help.
 Michael S. Palmer
Old Jan 17, 2011 | 03:50 PM
  #49
ReFtheMC's Avatar
Subscribing, thanks for write up OP!
Old Nov 20, 2011 | 12:31 PM
  #50
ISMELLRICE's Avatar
awesome just got some time to do it and worked great...
Now I can pressure wash my car lol
Thanks
Old Dec 13, 2011 | 04:25 PM
  #51
sneaky7980's Avatar
Thanks
That's a badass looking TA in your sig!!
Old Dec 19, 2011 | 10:02 PM
  #52
BADFNZ's Avatar
Not sure how I've never seen this thread.
I had my driver's side regulator replaced under warranty back in 2002 or so and after I got home, I realized my window wouldn't roll up all the way with the door closed. To roll it up all the way, I had to open the door, roll it up, then close it. I took off the door skin and realized the idiot riveted the new regulator into place about an inch from the original spot. Basically the window was tilting in too much, so it was getting caught inside the weather stripping instead of outside.
So it's been this way for damn near 10 years and I haven't bothered messing with it. I guess I could drill out the rivets and replace them with bolts to make it adjustable. Or it sounds like all I might have to do is move the brushes out a bit.
Good thread!
Old Feb 16, 2012 | 09:26 AM
  #53
za1cs's Avatar
this has helped me out alot , with my drivers window .. but from reading the earlier posts it sounds like my passenger window needs a new motor . ive heard of the shoe box method but cant seem to find it anywhere
any help ?
Old Jul 21, 2013 | 09:03 PM
  #54
BartZ28's Avatar
Default Wish I had....
seen this thread before I spent six hours (even with the Shoebox and the excellent Youtube mentioned below replacing a driver's side pw motor only to still have the 1/8" gap between the window glass and power mirror bezel. My first time replacing a pw motor. Now that I have discovered this thread, I will give the adjustments mentioned in the thread a try tomorrow. Hopefully that will be the ticket to success. Here is the excellent window motor replacement Youtube previously mentioned. http://www.youtube.com/watch?v=gqDseIbmV3g"]Ls1/Lt1 Camaro Trans Am (Window Motor Install). Thanks to all the contributors.
Old Jul 22, 2013 | 11:54 AM
  #55
Fluffy6079's Avatar
I'm so glad this thread has popped up. My driver's side window doesn't seal properly against the sail side and it raises too high some times. Not to mention that it feels like it may be jumping...
Thanks for the info!
Old Dec 19, 2013 | 03:21 PM
  #56
Pchurchill's Avatar
Thanks for the write up! helped me fix my window. Before I'd have to open the door, roll the window down, and then close the door before rolling to window up or else the window would sit like outside the t-top weatherstripping.
On question though, is there a way to stop the window from moving back and forth when partly open? (from the front of the car to the rear of the car). If it's not all the way up I can grab the window and move it back and forth. Thanks!
Old Mar 27, 2014 | 08:22 PM
  #57
sneaky7980's Avatar
Spring time bump
Old Sep 3, 2014 | 08:00 AM
  #58
Holybeen3341's Avatar
Default Still leaking
I tried this on mine to no avail. Made mine worse no separating panel but my hinges are a little wore. Not enough for this though. Here are my results.
Overlapped
Shy of stripping on front corner
Heres where the water gets in
All the way tight in the front stop. Even adjusted it all the way up. Its tight int the mirror piece too
Any suggestions appreciated before i set it on fire. Although probably wouldnt burn from the water
Old Sep 3, 2014 | 11:33 AM
  #59
big_g's Avatar
To be honest man, when I did mine I had to sit out there and fiddle with every single adjustment until I got it right. Just takes time. Yours is pretty far off though!
Old Sep 3, 2014 | 04:26 PM
  #60
Wasnt as bad until i messed with it. Mine seems to be gapped in a different way. Gonna give it another go soon
