Window alignment write up
Old Mar 3, 2008 | 08:26 PM
sneaky7980's Avatar
Originally Posted by maxgee
This should be in a STICKY!
I just used this and adjusted my driver's window and closes up tight!
Thanks
Glad it helped. Next project i'm working on is substituting the motor for a more durable version....
Old Mar 3, 2008 | 09:48 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm going to have to do this to my 95. The whistling sound from the passenger's side is driving me insane. I'm going to do the window motors at the same time.
Old Apr 7, 2008 | 11:55 PM
95TransAm_ToM's Avatar
I think i have a regulator problem with my 95 TA, it seals at the top of the Drivers side window but not on the back side of the window like this- Dummy proofed it
Old Apr 8, 2008 | 01:03 AM
theres like a 1/2 inch gap between the window and the weather striping, this pic isnt my car.
Old Apr 8, 2008 | 05:20 AM
gotspeed13's Avatar
Mine is doing the exact same thing. I'm going to have to read this write up so I can get it adjusted.
Old Apr 8, 2008 | 12:20 PM
sneaky7980's Avatar
Read through the write up and check out the pics. A little experimenting and you should be able to fix it.
Make sure your brush assemblies are still intact. They tend to break over time and you'd be surprised at how much they affect your seal. Also keep in mind that when adjusting your regulator, that sometimes moving some bolts in the direction contrary to to what common sense would tell you, will fix your problem. All i can say is go slow and adjust one thing at a time!
Good luck!
Old Apr 8, 2008 | 12:53 PM
thanks dudes
Old Apr 10, 2008 | 03:29 PM
goat-ee's Avatar
I didn't see any suggestions for this problem. What needs adjustment for this?
Old Apr 10, 2008 | 09:23 PM
sneaky7980's Avatar
It looks like your outer door skin is starting to come un glued. I had a 94 (same color even) that did the same thing. If you look at where the door skin meets with the door body, you see where it has separated along the top of the vertical edge.
lmk what you find...
Old Apr 10, 2008 | 09:25 PM
sneaky7980's Avatar
forgot something. If your door skin comes loose, the rubber weather stripping on the door that rubs against the outer side of the window will not hold your glass as tightly against the body when the door is closed.
Old Apr 10, 2008 | 11:48 PM
goat-ee's Avatar
I just looked that's exactly what it's doing, in fact both doors are separating, what do you do about that?!??! Can it be re-glued or something? A huge PITA?
Old Apr 11, 2008 | 04:35 PM
  #32
sneaky7980's Avatar
I never fixed mine, i just sold the car. Iwould imagine it's just apply glue, press together and wait. The only thing that could be an issue is if the adhesive requires all the old stuff to be removed. That could be a little tricky.
Post up your problem in the paint and body work section and im sure you'll get the info you need!
Old Mar 4, 2009 | 10:26 PM
  #33
mrhzk35404's Avatar
Just wanted to bump a good thread.
Old Mar 4, 2009 | 10:39 PM
  #34
PhantomR/T's Avatar
maybe now mine can stop leaking from the corner at the rear of the driver's side window. I'm sick of water in my damn car
Old Mar 5, 2009 | 07:14 PM
  #35
mrhzk35404's Avatar
I think this thread is sticky worthy.
Old Mar 20, 2009 | 01:06 AM
  #36
baldwintpenguin's Avatar
i'm bumping this thread, I think this might just save me alot of frustration tomorrow
Old Mar 22, 2009 | 10:30 AM
  #37
sneaky7980's Avatar
Hope it helps, it's getting that time of year for for some window problems again! I've got another one going out myself.
Old Apr 11, 2009 | 02:17 PM
  #38
strikeone's Avatar
thanks a ton for the write up sneaky7980 - it worked to perfection.
I spent 10 minutes disassembling the door panel, and then - BAM! Adjusting bolts D and E, the window snugs up right up where its supposed to be. thanks again.
Old Apr 17, 2009 | 04:07 PM
  #39
sneaky7980's Avatar
Glad to help. Now install my headers and we're even! :
Old Nov 14, 2009 | 07:14 PM
  #40
sneaky7980's Avatar
Its' that time of year where the rubber trim gets a little stiff. Keep that in mind if your having seal problems.
