window sweeps scratching the glass
Old Jul 17, 2007 | 08:10 PM
johnson7454's Avatar
Default window sweeps scratching the glass
does anyone else have this problem? Every glass i see from a junkyard is scratched from the window sweep. That is why iam trying to find a new window cause my driver side has heavy scratched from one bad roll down.
Old Jul 17, 2007 | 08:15 PM
Brian2006's Avatar
If you pull the door panel off there is a metal support that holds the window in place near the top. They come with a rubber end to not scratch the window but sometimes after tint install the place knocks the rubber end off.
Old Jul 18, 2007 | 11:27 AM
Danny2tek's Avatar
when I replaced my window motors I found them inside the doors apperently they break off easily
Old Jul 18, 2007 | 08:34 PM
76LS1BIRD's Avatar
Restricted User
I also found 1 inside my door.
Dale
Old Jul 18, 2007 | 08:49 PM
mike98ta's Avatar
does anyone know what they are called?
cause same thing happened to mine. and i have noticed on alot f bodies including mine that its on the driver side.
Old Jul 18, 2007 | 09:13 PM
InsaneAuto86's Avatar
window stabilizer 10257988
Now the hard question is what are the felt pads on the OUTSIDE of the windows? There are three of them and they are metal with felt on top of them.
Old Mar 26, 2010 | 10:54 PM
transam2000ls1's Avatar
Default window sweep removal
im getting my t/a ready for paint and i want to remove the window sweep. but it seems everyone i talk to about it says i should just replace them because the clips will break when i try and remove them.Is there any way to remove them without breaking them?
Old Mar 26, 2010 | 10:57 PM
sorry about that thought i was making a post of my own
Old Mar 27, 2010 | 02:14 AM
mxmccarter2401's Avatar
I took mine off, wrapped it with a piece of microfiber towel I had and reinstalled.
