strip between t-tops on a t/a
Old Aug 16, 2007 | 08:58 AM
n2ojunkie's Avatar
Default strip between t-tops on a t/a
OK I went to wax the car yesturday and I cannot get that strip to shine no matter what I do. Its been that way sence I bought the car but I always thought it was a part I forgot or something.
Its almost like they forgot to clear coat it.
Any sugestions? This is what I have done to it so far, I washed the whole car with dawn so I could start over on it as its been a few years (storage).
Then I tried the clay bar on it, scratch remover(celarcoat) wax, spray detailer, and lots more wax. It seams if I leave the wax on for awhile it does shine up some but not much. I left it on over night and I havent been out there yet today but Iam sure its not much better.
If I need to take it off and paint it do I just take the screws off on both sides or is there something else holding it?
Thanks
Old Aug 16, 2007 | 10:29 AM
Brian2006's Avatar
It's more than likely faded from the sun. Pretty common. I believe there is some sort of compound out there to fix this issue but seeing the amount you have already tried to resolve it with, you might just have to repaint.
Old Aug 16, 2007 | 11:39 AM
n2ojunkie's Avatar
that's what I thought. oh well the cars going to be down all winter for a turbo install so seams like a good time to do it.
How do I get it off is it just the screws? thanks.
Old Aug 16, 2007 | 01:15 PM
ZexGX's Avatar
Try some Nu Finish or something very close to that and THEN some wax first. If that doesn't work then it was still cheaper than a repaint, and you've got some chrome polish (Nu Finish doubles as a chrome polish). Chances are though that you'll have to repaint the piece.
Old Aug 16, 2007 | 01:17 PM
ReFtheMC's Avatar
I heard back to black works pretty good
Old Aug 16, 2007 | 01:35 PM
ZexGX's Avatar
Back to Black is only for plastic/rubber surfaces or painted surfaces without a gloss clearcoat. It's alcohol based so you probably wouldn't want to use it on that t-top divider, but it's worth a shot before attempting a repaint. My advice would be to try a drop of the stuff on an inconspicuous section.
Old Aug 16, 2007 | 09:37 PM
FLA02TA's Avatar
I sanded mine with 2000 grit, and then used a dryer sheet with some polish. Came out like new.
Old Aug 16, 2007 | 09:46 PM
kevinclark09's Avatar
I didn't know this until after I tried it on this piece. All it did was run off and make a mess, and I had an $8 bottle lying around useless.
I may try sanding it, and then polishing it.
Old Aug 16, 2007 | 10:29 PM
ZexGX's Avatar
If you decide to do that, let us know if it works (before+after pix would be awesome, too). =)
Back to Black is useful on our F-Body cars for the windshield wipers+arms, textured plastic trim around the bottom of the windshield, and the side molding (if it doesn't have a gloss clearcoat on it). I use it every two months on the plastic exterior trim and wipers+arms.
Old Aug 17, 2007 | 07:36 PM
Camaro Z's Avatar
I just unscrewed mine, spray painted it black with coat of clear on it and looks better than new
Old Aug 17, 2007 | 11:43 PM
'00_Z's Avatar
Try a round of cleaner-wax followed by some polish and a little elbow grease. I did that on mine and it came out pretty good. I finished it off with some carnuba to protect it.
