Project "ObseSSed"
Old Mar 8, 2011 | 07:16 PM
  #841
trans1998am's Avatar
your air ride
Old Mar 8, 2011 | 07:27 PM
  #842
slammed1500's Avatar
Originally Posted by trans1998am
your air ride
it was all custom done by me so
Old Mar 9, 2011 | 11:54 AM
  #843
JasonWW's Avatar
Hey Kenny, I've been thinking a lot about how you extended the wiring on the drivers side and moved that bulkhead connector to just in front of the door. I think that would work really well for me.
Was it a pain in the *** to move the inner bulkhead piece on the inside of the car?
Old Mar 9, 2011 | 12:48 PM
  #844
not really a pain just alot of wires
Old Mar 9, 2011 | 01:06 PM
  #845
JasonWW's Avatar
So you had to extend all the wires on the inside as well?
Old Mar 9, 2011 | 01:21 PM
  #846
JasonWW's Avatar
I'm doing something a little slick until I'm able to remove the shock towers completely. I'm welding the upper control arm plate into place and filling in the bolt holes. I already welded all the visible seams and smoothed them with bondo. It should make for a completely smooth shocktower. Whatcha think of that idea?
(The shocks are getting new rod-end mounts)
Old Mar 9, 2011 | 01:27 PM
  #847
no just the out side
Old Mar 9, 2011 | 01:29 PM
  #848
that should work
Old Mar 9, 2011 | 01:49 PM
  #849
JasonWW's Avatar
Cool.
I've got a 98 TA donor car. I might be able to cut it's harness from the bulkhead connector to the fuse box and then cut my cars harness at the connector. Then splice the 2 together to make it extra long. No need to buy wire and it's only half the splicing. Hopefully they will be almost identical.
Thanks for the info.
(Edit: it looks like it will give me another 28" and that looks like plenty.)
Old Mar 9, 2011 | 02:14 PM
  #850
Cool.
just # or lable each wire if your going 2 cut all the wires at once
because there are alot of the same colors
Old Mar 9, 2011 | 05:04 PM
  #851
JasonWW's Avatar
I think we can all agree that the fuse boxes are ugly and seldom accessed. So what if I put both of them behind the drivers side, front tire? There is room and the extra wire can be looped to the side or shortened. All you'd need to make is a sealed access door in the plastic splash guard. Then extend only a few wires instead of all of them. Hmmm, out of site, out of mind. If you need access, just turn the wheel all the way to the left and open the door. I'm digging it!
Old Mar 9, 2011 | 05:07 PM
  #852
SOMSS1LE's Avatar
Are you going to end up grinding everything down and painting everything that you are modifying, creating in the engine bay?
Old Mar 9, 2011 | 05:40 PM
  #853
JasonWW's Avatar
Is that directed at me or the OP, Kenny?
If your asking me, I don't have any definate plans. I'm smoothing the shock towers for now. The rest is built of square tubing so there's not much else to smooth out. Cosmetics are key for me so it will all come together in the end.
Old Mar 9, 2011 | 08:28 PM
  #854
yes it will all be smooth
Old Mar 20, 2011 | 09:43 PM
  #855
picked up on a spare ls1, it was practically given 2 me
might build it for some boost
cleaned and oiled up for storage
Old Mar 20, 2011 | 09:57 PM
  #856
MeenZ28's Avatar
damn, i wish an LS1 was given to me....
Old Mar 20, 2011 | 11:24 PM
  #857
The Mighty Texan's Avatar
No joke wtf! Looks like it could use a little attention though
Old Mar 21, 2011 | 04:34 PM
  #858
i got it for $50 lol
i usually dont come across deals that so i was a lil shocked
it only supposed to have 12,xxx miles on it
Old Mar 21, 2011 | 04:50 PM
  #859
PERFECT Z28's Avatar
awesome deal
Old Mar 21, 2011 | 05:32 PM
  #860
squee's Avatar
Would you sell it to a local in desperate need to get his DD back on the road? Say for 1000% profit?
