Project "ObseSSed"
Old Feb 26, 2011 | 11:53 AM
  #821
slammed1500's Avatar
just got my new radiator in
Old Feb 27, 2011 | 12:14 PM
  #822
MeenZ28's Avatar
Oooooo purdy
Old Feb 27, 2011 | 12:52 PM
  #823
Irish350's Avatar
very nice.. any info on the radiator/shroud/fan setup? looks like its the ac condenser too right?
Old Feb 27, 2011 | 01:27 PM
  #824
its a griffin radiator/shroud and im using the stock condenser
started cutting the upper and lower support out
and i got some primer on the bumper
Old Mar 1, 2011 | 08:13 PM
  #825
Old Mar 1, 2011 | 09:01 PM
  #826
JasonWW's Avatar
Nice. I assume you'll grind, bondo and sand it smooth?
Have you had any issues with turning the wheel when the car was too low?
I'm guessing you'd hear it rub and either straighten the wheels out or lift the front up with no damage.
I'm trying to decide whether to do a front tub like yours or add some room to turn the wheels when lowered. Hmmm. Any thoughts on that?
Old Mar 1, 2011 | 09:44 PM
  #827
it will be covered with that fiberglass cover i did just need 2 modify it a lil for the new setup
i just decided 2 do the new radiator 2 clean up the front of the engine and plus it makes room 4 when i do decide 2 go F/I
the only time i ride really low is when im going strait
but your wheels are wider than mine so it might be a good idea
Old Mar 1, 2011 | 10:49 PM
  #828
JasonWW's Avatar
Did you ever show pics of your rear suspension mods? Like the shock mounts and panhard bar?
Old Mar 1, 2011 | 11:00 PM
  #829
i think i did but here is 2 if not
new panhard and shock mounts
Old Mar 1, 2011 | 11:05 PM
  #830
JasonWW's Avatar
Cool, thanks.
You really had to move that panhard mount down a lot. Did that allow you to leave the passenger side mount in the stock location?
Old Mar 1, 2011 | 11:11 PM
  #831
Cool, thanks.
i set it up by finding the total amount of travel in the rear and put the panhard bar level in the middle of that distance
so that it would have minimal movement as the suspension goes up and down
and yes the passenger mount is stock
Old Mar 2, 2011 | 12:03 AM
  #832
MeenZ28's Avatar
I live for the pics in this thread
Old Mar 2, 2011 | 04:15 AM
  #833
S2VYSS's Avatar
Very good looking project
Old Mar 6, 2011 | 06:28 PM
  #834
moved the lower part of the support down 1 3/4"
made some mounts for the condenser
moved the latch support mount
i had 2 cut the close out panel i made 2 fit the factory radiator top
ill re fiberglass it 2 fit the support
Old Mar 7, 2011 | 12:15 AM
  #835
JasonWW's Avatar
Looks good. Was the new rad a bit taller?
I need to make a radiator duct. Your a wiz with fiberglass, do you think it would work well for that?
I figure I'd need to make a few flat pieces, then cut them to exact size then fiberglass the joints. Would a big flat piece of cardboard covered in tin foil make a good foundation to make them?
It might be a waste of money compared to using sheetmetal. Then again, I could make the complex, curvy part of the shroud from fiberglass and then the big flat pieces from sheetmetal. Hmmm
Old Mar 7, 2011 | 07:46 AM
  #836
the new radiator is only 15" tall i had 2 lower the bottom support for the condenser
i put foil over a piece of MDF 2 make my flat fiberglass parts and then trim theme 2 fit
Old Mar 7, 2011 | 10:12 AM
  #837
SS1Eagle's Avatar
Interesting project you have there!
I saw a ginormous bucket of seashells on your garage floor a few pics earlier.
You must be fond of seafood or I'm guessing that's abrasive blasting media?
Overall, this thread has turned positive for the "dare to be different" theme. I'll give you credit for that.
Old Mar 8, 2011 | 06:23 PM
  #838
Old Mar 8, 2011 | 06:31 PM
  #839
trans1998am's Avatar
I think its bad *** how much did it cost? I know someone already probbaly asked that but I just saw it.
Old Mar 8, 2011 | 06:47 PM
  #840
did what cost?
