Sap on my car!!!
Old Sep 27, 2007 | 08:17 AM
nhra_crazy's Avatar
Default Sap on my car!!!
Anyone know what will take sap off a car easily??? I cant get this crap off!!
Old Sep 27, 2007 | 08:22 AM
Jon5212's Avatar
Try using Goo Gone.
Old Sep 27, 2007 | 08:45 AM
Gipraw's Avatar
clay bar.
Old Sep 27, 2007 | 09:08 AM
Trent's Avatar
Originally Posted by Gipraw
clay bar.
Absolutely clay bar yes! Takes it off no problem and cleans up your paint at the same time
Old Sep 27, 2007 | 09:26 AM
Photochop's Avatar
pick off what you can, and rubbing alcohol works well to get whats left.
Old Sep 28, 2007 | 08:34 AM
LANDONZ's Avatar
WD40 works well too
Old Sep 28, 2007 | 02:02 PM
TARaptor's Avatar
i second this.
Old Sep 28, 2007 | 06:28 PM
KrazyDan's Avatar
Originally Posted by TARaptor
i second this.
then rewax the area
Old Sep 28, 2007 | 06:57 PM
Rob98LS1's Avatar
I scrape as much as I can with a razor blade (very careful), and then get a coarse rag along with some label and adhesive remover and scrub until the bottom layer is off. There may be fine scratches left in the paint afterwards depending on how long you scrub, so its always a good idea to apply some quick polishing compound and wax for original finish. good luck!
- Rob
Old Sep 28, 2007 | 07:00 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
Originally Posted by LANDONZ
WD40 works well too
If that doesn't work..sandpaper. [seriously,WD40 is amazing for a multitude of things]
Old Sep 28, 2007 | 08:54 PM
Gipraw's Avatar
Clay bar, or the alcohol mix is the best, and safest way to go..
if you go the WD40 route, make sure you wash well afterwards, then rewax.
- Rob
pretty severe way to attack tree sap ..
Old Sep 29, 2007 | 01:37 AM
Rob98LS1's Avatar
i wouldn't say severe, but thorough. I've never had a problem, and always a great finish.
Old Sep 29, 2007 | 09:26 AM
Gipraw's Avatar
considering the potential for damaging your finish, versus zero chance of damage with a clay bar or alcohol/water mixture .. I would call it severe.
obviously working for you .. but I would not recommend it to anyone.
Always use the least agressive method for defect removal.
Old Sep 29, 2007 | 09:36 AM
XLR8N's Avatar
zippo fluid works wonders, but like everyone else has said wax afterwords.
brody
Old Sep 29, 2007 | 10:44 AM
Gluemaker's Avatar
The rubbing alchohol is the easiest/cheapest/least harmful to do. Just put some on a rag and wipe hard. It'll come off within a few decent swipes. *DO NOT TRY TO SCRAPE THE SAP OFF THE PAINT* You can and will scratch the paint. Just use a rag and wipe that **** off with the alchohol. Then just to be safe quickly wax the area.
Old Sep 29, 2007 | 06:24 PM
Rob98LS1's Avatar
sometimes i forget that i have to do things as fast as possible at work and some saps just don't come off so easily with any rubbing alcohol mix. People doing it at home then ya not using a blade at all is the best way to do it.
Old Sep 30, 2007 | 02:01 AM
98REDZ's Avatar
I've run into this problem myself, I think I will try mineral spirits first hand and see how it fairs since I use it typically for any adhesive glue after removing emblems and its safe for clearcoat/paint.
Old Sep 30, 2007 | 02:49 AM
bmxer8699's Avatar
glad i found this thread, i just noticed i had sap on my car
Old Sep 30, 2007 | 09:04 AM
nhra_crazy's Avatar
Well I got it off guys. The goo gone worked very well with some rubbing. Then rewaxed it!! thanks again
