Used TROPI CARE FINALLY!!
#42
Well sure, that would be great. Im not a complete newb when it comes to detailing, im just a newb when it comes to using the PC, all the pads and what not seem to make a few things a lil bit more complicated. I know what im doing when it comes to hands on stuff tho.
From what i understand this is the basics of detaling, please correct me if im wrong.
1.Wash the car down with soap, either with dish soap to remove old wax
2.Clay bar
3.Swirl Remover
4.Sealent
5.Wax
6.A quick detailer OR a coat or two of Carnuba to give it a final shine.
#43
2.Clay bar
3.Swirl Remover
4.Sealent
5.Wax
2.Clay bar
3.Swirl Remover
4.Sealent
5.Wax
You can do either a synthetic sealant or a carnuba wax. Both are protecting layers. Synthetics are said to last longer but offers a more harsher/plasticky shine. Carubas only last a few weeks but give a more warm/rich shine. Frankly, I can't tell the difference in shine, though I do notice the synthetics bead water for a lot longer than carnubas.
If you want to go hard core, you can do both a synthetic and carnuba wax, thereby getting the best of both worlds. If you do, put down the synthetic first and do the carnuba second.
When adding multiple layers of wax (whether it be two layers of syn, or two of carnuba, or a caruba over a syn.), give each coat 12-24 hours to completely harden. Otherwise, you run the risk of having the second coat dissolve the first coat and you're no better off.
No need to use a detailer spray as part of the regular process. Instead, use it to dissolve wax (syn. or caruba) that you left on too long and can't buff off. Or use it between regular waxings--on a clean car--to maintain the shine.
#46
2.Clay bar
3.Swirl Remover
4.Sealent
5.Wax
2.Clay bar
3.Swirl Remover
4.Sealent
5.Wax
1.wash car with the soap in the kit
2. claybar
3.PC, Orange pad, and swirl cutter
4. hand application on hard to reach place with microfiber applicator and swirl cutter
5.detail spray (to get off any left over swirl cutter)
6. PC, Blue pad, sealant/wax
7. hand application
8. Detail spray again.
9. windows with their weave towel for windows(buy separate but definitely worth it.)
10. wheels with mothers mag and aluminum polish,(I did by hand would be better with power ball)
11. Interior sweep wipe down etc.
12. make sure everything is good use detail spray on anything needed
Those were my steps the PC is very easy to use and does nice work I used setting 5 for the swirl and 4 for the sealant. hope that helps
