Jumped on the Bandwagon - Bought the halo/proj. headlights
So for some reason (Nathan is being very helpful in helping me with solutions) the H3 kit isn't getting power or something to the bulbs. When I run them directly to the battery, they light up nicely but when I go through the stock connector and headlight switch, nothing but brights and halo's. However, I put the stock bulbs back in and all works fine...except the passenger side low beam halo is very very dim. (see pics in original post)
That sucks that the lights are fogging up. Considering how much they run for. You are going to have to reseal them. As far as the HID goes, it seems as though the ballast is not getting enough power or the ballast is bad. Did you try swapping the ballasts from the non working side to the working side to see if it is bad. Same goes for the bulb. Try swapping them from the non working side to the working side. This might help you rule out if the ballast or bulb is bad. Sometimes the stock wiring can not provide enough power. I myself run a relay harness that powers the ballasts from the battery. You may want to consider getting one.
Mike
Mike
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Mike
Mike
I did try, when troubleshooting, swapping ballasts/bulbs into every combo I could think of. I kept getting same results, nothing from the bulb. Nathan mentioned the same thing of putting in a relay. I may hold off on that for now until I find a better and higher quality headlight/halo assembly.
Hmm, I'll go back and double check but wouldn't both halo's be dim since they run off the same ground?
Sending both headlight assemblies back to the company for them to replace them due to non working halo and moisture getting inside. They supplied me with a prepaid UPS postage sheet, so they're covering the full shipping cost which is cool with me. So, I'll wait till i get the next set adn see if they're 100%.
stay tuned...
stay tuned...
they will tell you that they are currently out of stock of them and will have some in about 3 weeks, they will refund you your money and tell you to reorder in 3 weeks, but in reality they are bullshiting and have them in stock, they dont want to deal with you anymore....beleive me i was there already
#32
my eagle eyes version 2 fog up too. driver side projector has a very lame cutoff while the passenger side looks good. my corners from the same auction fog up and i tried sealing them up before i installed them but no help.
broke one of the tabs already too.
bought a bad hid kit too.
shitty deal but i'm going to try to live with rather than risking to lose more money.
#33
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Doesn't make much sense to me...did they charge you the 20% restocking fee or whatnot?
Damn....wondering if I should start looking for something else now
#35
I've got the same headlights... got them for free though lol... ordered 1 set they sent me 2. Sold the other set on here. But overall I'm happy with them they are bright as all hell much brighter then the stock headlights on my car, but I think mine are positioned a little higher up. Havn't had anyone complain to me about it yet. My halo's are very bright all the time, they take a bit to warm up mind you and break it in seemed in the beginning. I'm happy with them though. I wired mine to the DRL's and cut the power to the amber lights... all my amber lights do now is turn signal lighting.
#37
I've been sitting on my hands with this process. I did send them back and to my surprise, they were very quick in shipping another set out to me. I haven't even opened the box yet, been debating on selling them and the hid kit...haven't made up my mind for sure.
In the meantime, I've been very happy with the sylvania bulbs for stock headlights.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#38
i have these lights disassembled in my room right now.. they are horrible craftsmanship. horrribllle.. I have yamaha R1 headlights with the projectors i am going to fab into these for a real cut off. but you know what? I probly wont even use them. the projector lense isnt like this: ) its like > really pointy, not correct, they are sposed to be rounded.
#39
In the meantime, I've been very happy with the sylvania bulbs for stock headlights.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
