Please HELP scratches got PICS!!!!
Just want your suggestions and help on whats the best way of removing,hiding or fixing the scratches.
just want the best solution what do you guys do.
or if there are any good kits out there for me to buy
and how hard will it be for me to do or cause more damage if not done right???
or should i just take it to the professionals (detail shop)
flash...the specs is just dust washed the car the day before
no flash
This is the worst part of my car...the wing thought it would be a nice place to try out since imma get a ss wing later on
thanks
http://fasttoys.net/shop/index.php?cPath=831
now what are the dangers of porter cable it it possible to burn or even do it too much??
whats a cutting compound? like a conpound used in to sand with the porter cable??
well im thinking of buying the $161 tropi-care deal with the portercable. wondering if its enough for my car.
p;us i heard is like wax it will sooner or later come off so i wanna save money now and do it right the first time.
some of those look pretty deep, beyond the ability of the Porter Cable. A rotary in the hands of a professional can give you 100% swirl free.
Start here: https://ls1tech.com/forums/appearance-detailing/263061-porter-cable-dual-action-polisher-faq.html
-Mike
Start here: https://ls1tech.com/forums/showthread.php?t=263061
-Mike
well i think imma buy the kit anyway but will plan to take it to a pro. ill start on the wing since if i do **** it up i can get and ss one
if anything a good detail shop...need a pc anyways have 4 cars..ill practice with those first.
no flash
thanks
Everyone who begins by using a Porter Cable as a beginner or novice will realize that it takes time and experience to learn what the machine can do. The key is not to get frustrated or impatient during this learning process. Used correctly, it can remove about 80-90% of the surface blemishes using the right combinations of foam buffing pads and products. Once the surface has been buffed and polished to your desired level, future maintenance will be much easier to do.
The most visible scratch running diagonal in the top central area of picture #1 may be the most difficult to remove especially if your fingernail catches in the scratch. Typically the entire surface coating is only about 6/1000s of inch thick including to the base. That's about the thickness of 2 sheets of paper. Scratches or paint chips that are too deep to correct by wet sanding and polishing with a rotary, they may need to be addressed by touch up or repaint.
It is very difficult to to do any further damage to your paint short of dropping the machine on the surface. Its dual action performance to does not generate enough heat to do any clear coat damage even with cutting pads and rubbing compound combinations.
so nice detail shop and have the porter cable for use on the next detail witch should be easier since it will be in better shape.
yeah i can run my nail and i will feel the scratch
So what products and with what buffer do you guys use. like polishe,wax,cutting compound?
her name is heather and she is a rep for adams polishes, i just went to their polishing seminar and holy ****, my car is amazing, i got scrathes out that i thought were done, bird **** all kinds of blemishes my car is smoother than a bran new ferrari
