Write Up: Traction Control relocation (pics)
Old Jun 17, 2008 | 04:30 PM
ABJ88's Avatar
I'll be jumping on the band wagon myself.
Old Jun 17, 2008 | 05:25 PM
Nauty99SS's Avatar
bought a billitt cover awhile back , but what do the wires control ? the traction control ?
Old Jun 17, 2008 | 05:57 PM
presto_z's Avatar
yes.. if you disconnect the wires the TC will be off all of the time, so if you want TC you would need to extend the wires...
Old Jun 18, 2008 | 08:42 AM
SIC LSX's Avatar
i was happy to get rid of my TC.
Old Feb 10, 2009 | 02:29 PM
SIC LSX's Avatar
bump for wveryone else to see an do
Old Feb 10, 2009 | 05:25 PM
Magnet's Avatar
this is a great mod
Old Feb 10, 2009 | 05:45 PM
Engine_HP's Avatar
clean work
Old Feb 10, 2009 | 06:01 PM
Big Bird WS6's Avatar
could a person buy shortened pedel cables? so they sit furthere under the firewall
Old Feb 10, 2009 | 07:32 PM
Snuffles's Avatar
The cables tuck under the cowl very well.
Even if you can get shortened cables, it's easier to use a cable fastener.
Old Feb 10, 2009 | 08:41 PM
Camaro Z's Avatar
Can you just unplug and delete the TCS all together or does it mess up anything with the pcm.
Old Feb 10, 2009 | 09:36 PM
Snuffles's Avatar
The ASR/TCS light stays on and you will lose cruise control if you unplug the unit.
Also, you're going to have to get a cable from a non-TCS/ASR car to replace your existing cable.
Old Feb 13, 2009 | 09:55 AM
  #32
99_Z_155's Avatar
What are you guys doing for the spots where harnesses and cables have rubbed the paint away? thats what keeps me from doing these things. same thing with the wire mod.
Old Feb 13, 2009 | 12:34 PM
  #33
hiltsy855's Avatar
Originally Posted by Snuffles
The ASR/TCS light stays on and you will lose cruise control if you unplug the unit.....
Post #17 says cruise control still works w/o the TCS plugged in.....
Old Feb 13, 2009 | 01:46 PM
  #34
White_TA_27's Avatar
Have any of you had problems with the cruise control not working good after you did this mod. I have but maybe I just don't have the module secure enough. Any ideas??
Old Feb 13, 2009 | 01:52 PM
  #35
SIC LSX's Avatar
Mine has been done for a long time NOT 1 PROBLEM! You can even keep your TCS if you make the wires long enough to plug back up. Cruise control works the same!
Even Justin (stangkilr) did it to his car
Old Feb 24, 2009 | 07:30 PM
  #36
hiltsy855's Avatar
I can confirm the cruise control still works properly even without the TCS module plugged in.
Old Feb 24, 2009 | 07:39 PM
  #37
nemss1's Avatar
^^^yes, it will. cruise control is its own seperate module and has nothing to do with the TCS module other than sharing the piece to control the throttle cable
Old May 4, 2009 | 10:32 AM
  #38
00Camary's Avatar
This should be stickied
Old May 4, 2009 | 10:56 AM
  #39
00Camary's Avatar
Did this over the weekend.... looks great! Thanks now off to do the wire mod
Old Mar 21, 2010 | 12:42 PM
  #40
priest01ss's Avatar
Default Wire Length
Could anyone tell me approx how much longer the TCS/ASR wires need to be extended if you already have the wire mod done?
