Chrome Vent Rings
Old Apr 20, 2008 | 08:21 AM
97ramsst's Avatar
Originally Posted by boyd
just use a small and flat knife,---there is a lip you have to lift ,once lifted with the knife you can easely pull them off, I guess QCON did not see these lips and forced the vents too much.
There is realy nothing to the install,but you have to look on how these vents are put into the dash ,and do not rush things ,it is not a 2 minuts job.Generaly the install takes about 1/2 hour.
Do you try to pull the entire vent out at once or just the center section (the part you mount the ring to?) I am looking at a center ring I have out now and there is an area with 3 little barbes on it...is that what actually locks into the dash? On the one for he passengers side it has those little barbes as well but also two large tabs on the end, do the lock in as well or just hold it in place?
Old Apr 21, 2008 | 12:13 PM
boyd's Avatar
Restricted User
the center ring has 2 small lips on each side.The ones from above are a bit smaller so I recommend to lift them there .Just stick the knife in or screw driver in the middle section and push it down and torwards you....it has to come off easy...hope it helps you
if not I send you a pic!
Old Apr 21, 2008 | 09:03 PM
97ramsst's Avatar
If you would send me a pic of where your talking about lifting.... ramsst1997@hotmail.com
Fedex tried to deliver my rings today but I wasnt home to sign for them, so I will get them tomorrow.
Thanks.
Old May 2, 2008 | 03:22 AM
boyd's Avatar
Restricted User
Thanks.
saw you installed them in an other threat of yrs ,nicest car I ve ever seen!
check his car out...especially under the hood
Old Jul 28, 2009 | 02:30 PM
boyd's Avatar
Restricted User
got a vent set made this weekend, if anyone needs it pls pm me
Old Jul 29, 2009 | 09:49 AM
99Ls1fever's Avatar
Do you still make these?
Old Aug 6, 2009 | 06:41 AM
boyd's Avatar
Restricted User
yep stil make these
