View Poll Results: how to wire the fog lights
on with hi beams
1
4.55%
on with low beams
5
22.73%
on with headlights (high or low)
11
50.00%
on with DRL's
5
22.73%
Voters: 22. You may not vote on this poll
when to havefog lights come on
Old Apr 28, 2008 | 01:07 AM
jester1614's Avatar
Default when to havefog lights come on
I just swapped a ta bumper to my 94 f-o-r-m-y, my main dillema is this; how should i wire them up
not sure if these are really options but these are what i am thinking due to not having the foglight switch.
1 wire them to the power for high beams, when the high beams are on the fogs are also
2 wire them to the power for low beams, when the low beams are on the fogs are also
3 wire them to both so that when the headlights (high or low) are on so are the fogs
4 wire them to the running lights so they are on when ever any lights are on
option 4 is the most appealing option for me. Right now i dont have any wire to run for a switch or the switch itself.
any one else have opinions
Old Apr 28, 2008 | 08:47 AM
PontiacFan's Avatar
Where's the "When necessary, in the fog." choice?
In some areas, it's Illegal to drive with them on, especially in the city areas.
Maybe you'd better look into your local laws first?
Old Apr 28, 2008 | 09:33 AM
95GreenZ28's Avatar
On w headlights- high or low. Imo
Old Apr 28, 2008 | 10:52 AM
tylerdj's Avatar
Just wire them up to their own switch.
Old Apr 28, 2008 | 12:19 PM
Ls1CamaroGuy87's Avatar
on with headlights high or low.
On my camaro I can turn them on with just the DRL's, low beams, and even high beams....also my high beams and low beams come on at the same time with the foglights....
Old Apr 28, 2008 | 10:22 PM
blindxeyed's Avatar
I just followed this guide on how to hook up the stock fog light switch to power the fog lights. It only gives power to the fog lights when your turn your ambers/parking lights on. As long as those are you, you can turn the fog lights on and off.
I lost the link to the original webpage. But luckily I saved it on my computer. I uploaded it for you in case you were interested. Here's the link:
http://home.comcast.net/~blindeyed/foglights/
Old Apr 28, 2008 | 10:30 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
ONLY MAKES SENSE....
Old Apr 29, 2008 | 06:44 AM
rspect's Avatar
Wire them to stay on at all times with your lights.
Old Apr 29, 2008 | 12:00 PM
wabmorgan's Avatar
Agreed.
Don't know if this helps... but in the Silverados.... the fog lights are set up on a seperate switch which ONLY works with the low beams on.
Old Apr 29, 2008 | 07:40 PM
mycamaroSS's Avatar
i couldnt vote for two things, so this is what you should do. Wire it so that they are on with your DRLs and when you have your high/low beams on
Old May 1, 2008 | 09:57 AM
SSquid's Avatar
What the hell kinda state says you cant drive with factory fog lights on? it helps you see better at night... its safer... helps you be seen... gayest thing I ever heard...
Old May 1, 2008 | 08:33 PM
cool whip's Avatar
When it's foggy out. That's what the wider beam is for. Don't blind other drivers unnecessarily.
Old May 1, 2008 | 08:41 PM
*98TransAm*'s Avatar
blind the other drivers? these fog lights aren't bright at all and imo are completely useless although they do look good right before it gets dark and your day time running lights are on with your fogs.
i think most laws say you can only have a certain amount of forward lights which is why your fog lights turn off when you hit your high beams. im pretty sure its not illegal to drive with your fog lights on when its not foggy. thats just retarted yet so are tint laws, so who knows
Old May 1, 2008 | 09:39 PM
1995blacktattop's Avatar
on with the parking lights... thats how they are wired stock... that way you can drive with the headlights down/off and the fogs on... how i drive a lot of the time at dusk/night unless i'm in an unlit unfamilliar area late at night..
FWIW i have some new bulbs in there that, while the same wattage as stock, seem a lot brighter than the stock ones that were in there...
Old May 1, 2008 | 11:13 PM
transam5.7lt1's Avatar
Wire them up with your horn...............
j/k, put them in a separate circuit.
