Help w/ gauge panel/mounting!!
Old Jul 3, 2008 | 10:39 AM
XxApollynxX's Avatar
Default Help w/ gauge panel/mounting!!
Well I have been searching on here and found all sorts of mounting locations accept for the one I am searching for I want to mount a gauge right next to the TCS button on the Trans Am which is front of the shifter. Will a gauge fit here or no? Does any body know if there is a pre-made panel or am I on my own for making a hole/mounting it there by my self. Heres a pic of where if any body is confused.
Attached Thumbnails Help w/ gauge panel/mounting!!-gauge-mounting-location.jpg
Old Jul 3, 2008 | 12:59 PM
Snuffles's Avatar
You can modify the one you have. Demonbird did it. See here.
Old Jul 3, 2008 | 01:13 PM
Brian2006's Avatar
By the way, do you ever have plans to create a mold of that bezel of yours Snuffles?
Old Jul 3, 2008 | 01:22 PM
vjo90rs8's Avatar
I used a 2 1/16" VDO gauge in that location. I will post pictures this weekend.
Old Jul 3, 2008 | 01:32 PM
AxisOfOil's Avatar
I'm not sure if anyone sells them. Just take a hole saw to it and get a gauge that has a bezel around it is how I would go about it.
Old Jul 3, 2008 | 01:40 PM
00_Z-28's Avatar
Beer99c5 (member on this site) did an amazing job on mine! I got a panel made for a single gauge, but I have scene some of his panels with as much as you could possible need in there. Send him a PM and I’m sure he can get what you need done.
Old Jul 3, 2008 | 02:02 PM
Snuffles's Avatar
I would love to have a mold made of it but it will likely never happen because of cost.
There's something else in the works though that I'm hoping will be a bigger hit and will be cheaper to reproduce.
Old Jul 3, 2008 | 03:35 PM
Brian2006's Avatar
details? you left us hangin like 6 months on your last project!
Old Jul 3, 2008 | 03:48 PM
Snuffles's Avatar
Yea, yea.
Fine. I'll get on it this weekend. By Monday night there will be a post.
/hijack
Old Jul 3, 2008 | 08:05 PM
Brian2006's Avatar
Yea, yea.
/hijack
thanks! But seriously getting a mold for your bezel would most definitely be worth the time/money.
Back on track
Old Jul 3, 2008 | 08:41 PM
So I would cut a slightly smaller hole so the gauge portion could slip threw but the top part would stop, how are your guys gauges secured in?
Old Jul 3, 2008 | 08:45 PM
1BADTALS1's Avatar
figure out the size of the hole and buy a drill bit.. hole saw. that size and cut it... pop in the gauge and be done...
Old Jul 3, 2008 | 09:47 PM
Snuffles's Avatar
Each company secures there gauges in differently.
Give us a company (ie: Autometer, Interceptor, etc.) and we can further help you.
Generally, most 2 1/16" gauges mount behind with roughly the same dimensions.
Old Jul 3, 2008 | 10:50 PM
I am using an Autometer ES Series (New) It's black face by day w/ white letters and at night black w/ RED LED lightning should go pretty good w/ the stock lighting.
Old Jul 7, 2008 | 09:18 PM
Bump!
Old Jul 7, 2008 | 10:27 PM
Snuffles's Avatar
Sorry, I must have missed this post.
You would cut a hole large enough to fit the gauge but not large enough where the bezel would fit through.
It seems you're looking at 2 1/16" (52mm) gauges. I mounted 2 1/16" gauges and had a 2" hole saw so I used that then Dremel'd (Did I just make up a word?) the rest.
The way the Autometer should mount is simple.
Autometer uses brackets that are rather low-profile and fit well.
Check out the Autometer site to see what I mean, here.
I also found a pic on Flickr to show how they mount, although the pic is quite complicated because he had to fab his own bracket
but I emphasized the bracket with red arrows,
Hope that helps.
Old Jul 8, 2008 | 11:55 PM
Now that I got the gauge in person, and saw it I saw that ring, and that what I was figuring use a 2" holesaw and dremel as needed. And now that I saw the bracket the autometer came with it all makes sense. =) Now just to get a deep pan.
Old Jul 9, 2008 | 05:38 PM
ProjectCamaro's Avatar
Beer99C5 made mine as well
