TA door panels in camaro
Old Aug 5, 2008 | 10:32 PM
7845's Avatar
Default TA door panels in camaro
yes did a search but didnt get the information i needed. i noticed that the camaro door doesnt have the holes for the TA panel to bolt in. what did you guys who did the swap do for this part? besides that any other issues anyone has encounterd?
i read the whole mirror doesnt work, i might end up using the TA door wiring
Old Aug 5, 2008 | 11:30 PM
black97ss's Avatar
just match up the wires for the mirror they are the same colors just different format, for the no handles i took a few bolts and bolted it to the side by the door handle, they seem to hold up well, for the summer so far havent needed any attention after i finished
Old Aug 5, 2008 | 11:31 PM
black97ss's Avatar
also camaro little locks, the little black piece with the orange sticker, it doesnt fit in the t/a door handle, so be sure to get t/a lock things whatever the hell youd call it
Old Aug 6, 2008 | 02:40 AM
LS1 FORMULA's Avatar
I am not hatin here. just wondering. Why would you want to put TA panels in when all they do is crack?
Old Aug 6, 2008 | 08:47 AM
3800RS's Avatar
I never hooked up the mirror when i did it. Someone told me you have to run new wires side to side. Basically you cut off the 2 middle tabs on the door that the camaro panel used to bolt in. Put the ta panel on and mark the spots to drill and put screws in.
Old Aug 6, 2008 | 02:40 PM
black97ss's Avatar
camaro door panels plain and simple lines, t/a has a little action to theirs, and to be different, make your car your own man
Old Aug 6, 2008 | 06:54 PM
7845's Avatar
i like the look of the TA door panel over the camaro. camaro reminds me of an old truck door panel and doesnt flow well with the car. also like the extra tweeter placement along with the angle of the speakers.
as for wiring if i have to i can get full TA door wiring with no problem
so the few of your are just running your own screws in the doors? anyone running backing support so the panel when pulled on doesnt break the inside part of door? right now i have the panel on but with no screws in place as im in the test and mock up phase of my camaro restoration
Old Aug 6, 2008 | 07:22 PM
Thule's Avatar
pics!! wanted to do this last 2 years
Old Aug 6, 2008 | 07:29 PM
brandotron's Avatar
Old Aug 6, 2008 | 09:24 PM
3800RS's Avatar
what i did was mark the spots where the screws were going. Then drilled the holes. Then what i did was take off that plastic square looking nut thing and relocated it to the new hole i drilled. Screw the screw into the black nut and wala !
Old Aug 6, 2008 | 11:17 PM
7845's Avatar
alright i was looking at door again and think what you 3800rs said is probably what ill do. ill tackle that once i finish lining up my nose alittle better
Old Aug 7, 2008 | 09:55 AM
black97ss's Avatar
Old Aug 9, 2008 | 11:41 PM
01ssreda4's Avatar
i would feel like a poser with TA door panels. sure camaros have shitty looking door panels in comparison but who cares.
Old Aug 10, 2008 | 12:19 AM
jsteele90's Avatar
guess maybe a benefit would be having another place to mount a speaker. the extra tweeter above the regular door speaker.
