what's needed to be done to...
Old Dec 3, 2001 | 06:39 PM
Slow Z28's Avatar
Default what's needed to be done to...
make 15x8 weld pro stars fit on the rear? some say grind down the fins on the caliper, others say nothing. should i run spacers on the back too? any help is greatly appreciated.
Chris
Old Dec 3, 2001 | 08:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: what's needed to be done to...
Chris, I had a few sets of 15x8 Prostars.
Grind grind grind.
I did not use spacers. I don't think it's a good idea. I'm sure someone has pics of where they grinded.
Old Dec 4, 2001 | 12:23 AM
y2kws6's Avatar
this is chris, i'm just at dan and jacki's house.....
what should i use to grind them down? belt sander? dremel? die grinder <img src="images/icons/wink.gif" border="0"> ? i am hoping this can be as painless as possible.
Chris <img src="images/icons/smile.gif" border="0">
Old Dec 4, 2001 | 12:51 AM
Loco's Avatar
Whats wrong with using spacers? I have spacers on my Welds but I dont like the way they look.
Old Dec 4, 2001 | 05:15 PM
Matt98SS's Avatar
with spacers you don't get as much of the bolt threaded into the lug nut which can possibly shear off then because of that. I used spacers for a while then decided to grind, grind, grind.
Chris I used a Craftsman Professional 4.5" 7 amp right angle grinder. Took NO time at all with this sucker!
Very worth it to me for no spacers looks better and wheels are basically flush then <img src="images/icons/smile.gif" border="0">
Old Dec 4, 2001 | 09:22 PM
Loco's Avatar
Good enough reason for me. I'll grind em this weekend. Thanks. <img src="images/icons/smile.gif" border="0">
Old Dec 5, 2001 | 09:08 AM
Z-28Hugger's Avatar
How many threads you get into the bolt will have no effect on sheer strength. How much engagement are you getting? The only thing you will have to worry about is pulling the threads off of 5 bolts with a sideways load. In theory anyway.
Old Dec 6, 2001 | 09:15 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I ran spacers with my 15x8 Pro Stars on my T/A, and I never had any problems. My quickest 60' was a 1.53.
__________________
Old Dec 13, 2001 | 10:31 AM
MelloYellow's Avatar
Use longer bolts with spacers.
