HUGE Interior Question!
Old Aug 27, 2008 | 04:19 PM
Jscotty's Avatar
Default HUGE Interior Question!
How the hell do you get the center console strip off?!
I have an A4. I haven't tried it yet but it doesn't look as simple as I'd like. Do I have to do something weird with the shifter.
Thanks guys,
Old Aug 27, 2008 | 04:31 PM
DUhulk78's Avatar
You need to take a flat blade screwdriver and carefully pry out the plastic staple on the front side of the ****, then it just slides off. Pretty easy.
Old Aug 27, 2008 | 05:03 PM
my bandit's Avatar
like he said pry out the staple then open the center console compartment and remove the coin holder. (should just slide up) the undo the 2 small screws under that and just lift up and out
Old Aug 27, 2008 | 06:04 PM
Kingc8r's Avatar
^ Yep that's how I did it, be very careful doing it as mentioned
Old Aug 27, 2008 | 06:27 PM
Jscotty's Avatar
Great, thanks...
What about the shifter? I need to get this piece totally out of the car... does the shifter come apart in a manageable fashion?
Old Aug 27, 2008 | 09:03 PM
97camarozguy's Avatar
The **** should just slide off once the staple is out. Once it's off, just slide the consol piece up and over the ****. Make sure you unhook the wires that go to the cig lighter and ash trey light.
Old Aug 27, 2008 | 09:15 PM
98 WS6's Avatar
I needed to know this also. I hate how ugly the A4 shifter is so I was thinking of doing the shifter conversion thing (manual shift **** on Automatic) and putting in a 6 Speed center console with the boot and everything.. Thoughts?
Old Aug 27, 2008 | 09:17 PM
DUhulk78's Avatar
I got an adapter and am running a B&M hammer shift **** and have ordered a newer grand am shift boot.
Old Aug 27, 2008 | 09:24 PM
schuby87's Avatar
Post up some pics when you get done with the Grand Am shift boot. I have been thinking about using one from a Grand Prix.
Old Aug 29, 2008 | 04:37 PM
WS6Jim's Avatar
Grand Am Boot may look nice but I went with redline goods for custom boots and console lid to go with my shift conversion. I liked the boot on the ebrake and console but I did not like it on the shifter . I have one available in charcoal leather with silver stitching if anyones interested for cheap. Not trying to hijack the thread though. Sorry.
Old Aug 29, 2008 | 05:36 PM
1998Z28LOADED's Avatar
Pull it up easy, there isnt much slack in the wire for the light under there. Be careful around the airbag stuff under there! I think I actually had to put the car in gear to be able to get it high enough to unhook the light before I lifted it. Hope that helps!
